How to erase the line after add component
bakuiseok
Post by bakuiseok »
OS: Windows 10 Version 2009
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Arch workbench in use. After adding components of the two walls together, a line is formed in the image below. Isn't it normal that I can't see the line if I put the wall together? I don't know why I see a line. And tell me how to get rid of the rope. Thank you.
new Model 208-18, Architecture B.FCStd
(427.25 KiB) Downloaded 21 times
onekk
Re: How to erase the edge after add component
Post by onekk »
Hello.
Please add FreeCAD full version info as required in IMPORTANT: post in top of page, it will be easier to know the missing info about you FreeCAD version.
Regards.
Carlo D.
- Various other stuffs.
Roy_043
Post by Roy_043 »
I think there are some inaccuracies in the model which result in neighboring faces that are not co-planar. For example the points of Wire032:
bakuiseok
Re: How to erase the line after add component
Post by bakuiseok »
@Roy_043 I connected the line using a snap tool, but I don't know why the location was wrong. Is there a way to solve this problem? Sometimes I used a snap tool, but I feel that it may not be accurate.
Roy_043
Post by Roy_043 »
The inaccuracies I see suggest user error. One thing to avoid is having Draft_Snap_Near permanently active. Also note that you can create a wall with an offset from the base wire, so Wire0032 could have been drawn on top of grid lines I think.
papyblaise
Post by papyblaise »
I confirm that wire032 and line009 are not aligned, as I never invested in the understanding of Draft, I transformed into a sketch and aligned the 2
and There you go
wall.FCStd
(335.64 KiB) Downloaded 11 times
