OCC error when trying to thicken a wavy surface
NewJoker
Post by NewJoker »
I am trying to apply a filled offset (Part Offset) to a wavy surface. Unfortunately, I am getting OCC errors regardless of the offset mode and join types:
offset error.JPG (75.45 KiB) Viewed 762 times
Any chances that it can be fixed ? Can you suggest some workaround ?
Wavy pizza cutter.FCStd
(27.49 KiB) Downloaded 20 times
OS: Windows 10 Version 2009
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Locale: Polish/Poland (pl_PL)
thomas-neemann
Re: OCC error when trying to thicken a wavy surface
Post by thomas-neemann »
NewJoker wrote: Sun Oct 02, 2022 6:06 pm ....
is this a solution for you?
Wavy pizza cutter-tn2.FCStd
(53.94 KiB) Downloaded 20 times
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.21.30486 (Git) AppImage
Hash: eb546e25d3f952869e3ec87dca02b58653cb3936
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
NewJoker
Post by NewJoker »
thomas-neemann wrote: Sun Oct 02, 2022 6:23 pm is this a solution for you?
Yes, it looks good, thank you. I don't why I didn't think about Part Extrude. I was following a tutorial in which offset was used.
user1234
Post by user1234 »
Just for completeness:
when you make a geometry check of the surface, you will see, that there are meany errors. The reason is because the array is not fused, so the seams of the array are open.
When it is fused, then the operation at least do something, but at least for me the result is invalid. But also my OCCT version is atm old (can not update because of an bug), on newer it could work better. If someone could test, this would be informative.
NewJoker wrote: Sun Oct 02, 2022 6:37 pm I don't why I didn't think about Part Extrude.
A extrude is not the same thing as an offset. An extrude only goes in one direction, a offset goes to the normal of the source surface (constant wall thickness). But because the wave is pretty "flat" at least it is a good near.
Greetings
user1234
Vincent B
Post by Vincent B »
or like this.
Wavy pizza cutter_vb.FCStd
(109.56 KiB) Downloaded 15 times
user1234 wrote: Sun Oct 02, 2022 6:57 pm If someone could test, this would be informative.
Doesn't really work here either. Only Joint type intersection yields a result:
OS: macOS 10.16
Version: 0.21.30430 (Git)
Hash: 9e1ed4a68ad43309c2b38f7f5efbb1feac4323cb
Locale: C/Default (C)
Installed mods:
  * FC_SU
  * FeedsAndSpeeds 0.4.0
  * fcgear 1.0.0
  * fasteners 0.4.6
  * sheetmetal 0.2.57
  * ExplodedAssembly
  * Curves 0.5.8
papyblaise
Post by papyblaise »
or other solution
pizzalolo.FCStd
(981.83 KiB) Downloaded 13 times
Vincent B
Post by Vincent B »
chrisb wrote: Sun Oct 02, 2022 11:29 pm Doesn't really work here either. Only Joint type intersection yields a result:
Because mirror carry out up side downed surface. need part_ReversedShape. See my file. ;)
