changing text font in 2d
Riedel74
Post by Riedel74 »
I know how to change font in 3d like the pic I have here but when I put the text from 3d to 2d it changes the font and I cant get it back.
so is ther any way to chose what text font I use in 2d? first pic is when I have it in 2d second is having the font I want to use.
OS: Windows 10 Version 2009
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Locale: Swedish/Sweden (sv_SE)
Installed mods:
  * A2plus 0.4.59c
  * Assembly3 0.11.3
  * Assembly4 0.12.4
  * fasteners 0.4.12
  * toSketch 1.0.1
onekk
Re: changing text font in 2d
Post by onekk »
Riedel74 wrote: Wed Oct 05, 2022 8:14 am I know how to change font in 3d like the pic I have here but when I put the text from 3d to 2d it changes the font and I cant get it back.
What WB you are using, FC has many places where you could specify a "font".
Some examples, among others:
  • ShapeString, you could change the font directly in the object property.
Annotations, Dimensions or or other things.
attaching a file with some examples maybe will be useful.
Regards
Carlo D.
- Various other stuffs.
Riedel74
Post by Riedel74 »
funny part now I seems to get the font working but when I change from 3d to 2d the size is not the same.
TEST FILE.FCStd
(14.97 KiB) Downloaded 18 times
onekk
Post by onekk »
Riedel74 wrote: Wed Oct 05, 2022 9:53 am funny part now I seems to get the font working but when I change from 3d to 2d the size is not the same.
Yes it depends from the 2D and 3D setting of the "Draft Label" it respect or not the .TextSize property.
From: https://github.com/FreeCAD/FreeCAD/blob ... e_label.py
"""Create a Label object containing different types of information.
The current color and text height and font specified in preferences
are used.
Probably this is set too high 1000.00mm the different thing is there is a different behaviour of the scale factor on the text depending on the 3d or 2d setting.
There is a reason for which behaviour but I don't remember what is.
See maybe: https://wiki.freecadweb.org/Draft_Label
@Roy_043 Please do you a have a better explanation?
Regards
Carlo D.
Roy_043
Post by Roy_043 »
I find it understandable that the size of the text changes when switching the "Display Mode" of the label. When the text faces the camera it has a constant height (relative to the screen), so only at a certain zoom level will the text keep the same height when switching.
onekk wrote: Wed Oct 05, 2022 10:47 am there is a different behaviour of the scale factor on the text depending on the 3d or 2d setting.
You need to explain this, I can't reproduce it.
onekk
Post by onekk »
Roy_043 wrote: Wed Oct 05, 2022 12:43 pm
If you use TEST_FILE.FCStd file in:
https://forum.freecadweb.org/viewtopic. ... 30#p630730
You will se that the measure are in mm but as example FontSize is 1000mm for the dLabel object if you change from 2d to 3d the dimensions of the text change "dramatically".
In that sense, (at least on my FC where units are mm).
Regards
Carlo D.
Roy_043
Post by Roy_043 »
Thanks, I thought you were talking about the "Scale Multiplier" property.
