OK to swap between Part and Part Design WB's ?
Using Version 0.20
Sequence:
-new
- part design WB
-create body
- import (SVG file from Inkscape, which is longitudinal section of half barrel) - as geometry
- path appears on screen, select it
Now I want to rotate the 2D shape into a barrel, if I go PD-revolution I get the message "cannot use selected object- must belong to active body". I've read some threads on this but can not see how to make that path part of the body. Anyhow, IF I change to Part WB I can use "Revolve" and get the resulting 3D model. I can even export this to the 3D printer slicer software and it is accepted.
However, if I change back to Part WB in order to access "hole" I again get the "cannot use..." message.
Is there a good explanation of Model tree hierarchy that would help, or am I swapping between workbenches wrongly? Is this part of the "topological naming" issue?
Cheers
Nelson
Sequence:
-new
- part design WB
-create body
Cheers
Nelson
Re: OK to swap between Part and Part Design WB's ?
PartDesign wb is based on sketches, shapebinders, datums and operations leading to solid geometry. All of them contained withing bodies. Part wb doesn't rely on bodies and its operations allow also for surface modeling. If you want to operate on wires (lines), Draft wb will help you. It's often necessary to mix those 3 workbenches when working with more complicated models. You just have to be careful with that. Sometimes even add-on workbenches like Curves get involved.
If some object supported by bodies (see above) is outside of them, you can drag it to a selected body in the tree.
- Shalmeneser
File ?
Full version ? (follow link in red banner !)
Part workbench is quite capable of using sketches. Entire, complex models can be made with sketches in Part workbench.NewJoker wrote: ↑Thu Oct 06, 2022 8:32 am PartDesign wb is based on sketches, shapebinders, datums and operations leading to solid geometry. All of them contained withing bodies. Part wb doesn't rely on bodies and its operations allow also for surface modeling. If you want to operate on wires (lines), Draft wb will help you. It's often necessary to mix those 3 workbenches when working with more complicated models. You just have to be careful with that. Sometimes even add-on workbenches like Curves get involved.
Yes, of course. I just listed objects that are contained within bodies in PartDesign. Part also uses sketches and solid modeling operations but it also include surface modeling. Too bad datums are only available within bodies.
Other than providing the occasional arbitrary axis for a mirror or revolve, I don't use them.
But, let's not hijack this thread.
To the OP's question; Part and Part Design workbenches can be used together effectively if the user understands the rules and subtleties of doing so.
Mixing them without this understanding will be, at a minimum, confusing.
- adrianinsaval
Short answer: use a shapebinder to be able to have a linked copy of the imported wire inside the body so you can use it on Part Design.
Import the SVG as geometry
In Draft wb select all (I had to delete some bad lines that was in my imported file)
Convert the selection in Sketch and delete the original import
Open the sketch and add coincident constraints and a construction line as a centerline for rotation.
Close the sketch and make a Body
Drag the sketch into the Body
Rotate the sketch around the construction line
Thanks Willem, and other responders. I could not get sound on that video - is that intentional? I need to follow more tutorials, and try out the suggestions, before posting further questions I think. I felt very pleased to have succeeded in importing the svg and creating my barrel shape, but got stuck trying to make further modifications to it.Willem wrote: ↑Thu Oct 06, 2022 1:38 pm Import the SVG as geometry
Attached is the file. Edit:
OS: Windows 10 Version 2009
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Cheers
Nelson
