sketch not padding
sketch not padding
Not sure what I am doing wrong but I can't seem to pad my circle sketch to the outer face. Please assist. Getting a multiple solid error...
- pad prob.FCStd
- (14.93 KiB) Downloaded 12 times
- multiple solid error.PNG (51.22 KiB) Viewed 366 times
- pad to face.PNG (14.02 KiB) Viewed 366 times
Re: sketch not padding
The error is self explanatory, there is a strict single solid rule in PD WB.
You are trying to pad a cylinder NOT in contact with the Pad.
Thanks Bance. I really need to go thru the fundamentals of FC!
- Shalmeneser
If you change 50um to -50um, you can pad it because you will get ONE continuous solid.
