The version of FreeCAD I use is:
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Hash: 68e337670e227889217652ddac593c93b5e8dc94
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.2
Installed mods:
* Curves 0.3.0
* LCInterlocking
When I open in FreeCad a model and I click in the model's tree or in the model itself, everything is still fine. However, if I move down the vertical scrollbar of the model's tree or rotate the model in the 3d view, then after each click in the tree or model, the "Object selection" dialog appears for no reason. I've gone through all the preferences, but I can't find how to turn that off.
The "Object selection" dialog screen appears for no reason.
- object-selection-screen.png (475.26 KiB) Viewed 481 times
Re: The "Object selection" dialog screen appears for no reason.
What is the object selection dialogue?
Maybe a screenshot?
Maybe a screenshot?
Screenshot attached.
Where do the check boxes in the tree view come from?
There is a setting in Preferences to show checkboxes in the tree.
So this dialogue is launched from the selection view, which would be below the combo view, this part is not included in the screenshot.
Did you try to close that if it is open?
Otherwise do you have any extraneous devices connected to your computer (joysticks, etc) if so try after disconnecting them.
I see it can also be brought by selecting an object then CTRL-C.
@djeear maybe try to hard reset your preferences (i.e. to rename the "%APPDATA%\FreeCAD" folder).
Thanks for your responses. I completely uninstalled FreeCAD 20.0, including my preferences and then installed FreeCAD 20.1. The problem has now disappeared.
