Grid problems in Draft mode
caliston
Postby caliston » Wed Aug 06, 2014 8:37 am
I'm trying to learn FreeCAD to do some basic 2D CAD (which might turn into 3D at some point, but not yet - a few rectangles with dimensions is all I need at the moment). I start with a fresh FreeCAD install, make a new file, go into Draft mode and draw a rectangle, altering the size to (say) 300mm x 300mm by entering numbers. I get a rectangle of appropriate proportions. But the grid seems to be stuck at 100x100mm maximum extent - so when I zoom out the grid is a small grey dot and the rest of my workspace has no grid:
I can't find any way to extend the grid. Various sources seem to suggest that it's supposed to resize with zooming in and out or after you draw objects, but even if I save, quit FreeCAD and reload the file, it comes back the same as it that screenshot. I can find settings to adjust the grid spacing, but not its extent.
I'm sure I'm doing something stupid here, what am I missing?
OS: Mac OS X
Word size: 64-bit
Version: 0.14.3692 (Git)
Hash: 1124a5751456ac6b8f9d6f1b470281ca67e572e2
Python version: 2.7.5
Qt version: 4.8.6
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
(I also tried the Linux version, which had the same problem)
cmittle
Re: Grid problems in Draft mode
Postby cmittle » Wed Aug 06, 2014 11:46 am
I see the same on mine.
OS: Ubuntu 14.04.1 LTS
Word size: 64-bit
Version: 0.15.3807 (Git)
Hash: f0d55647472ab5f9a1f8e96bb589b0941c43318a
Python version: 2.7.6
Qt version: 4.8.6
SoQt version: 1.6.0a
OCC version: 6.7.0
ickby
Postby ickby » Wed Aug 06, 2014 12:13 pm
you can set the grid size in preferences->draft->snap settings. As far as I know this can be set only to a fixed size at the moment.
yorik
Site Admin
Postby yorik » Wed Aug 06, 2014 10:09 pm
Indeed, the grid doesn't resize automatically (couldn't find how to do that nicely yet). You need to go in the Draft preferences and set the units there. You can also turn it completely off and not get bothered with it anymore...
caliston
Postby caliston » Thu Aug 07, 2014 2:56 pm
ickby wrote:you can set the grid size in preferences->draft->snap settings. As far as I know this can be set only to a fixed size at the moment.
How does this work? I go in there and there are two fields:
Main lines every: 10
Grid spacing: 1.0000
Y Always show the grid (ticked)
Y Use grid (ticked)
If I change Main Lines to 99 and Grid spacing to 23, it makes no difference on the view. I hit Apply, then OK, nothing changes.
There doesn't seem to be a 'redraw' menu option, but if I switch to any other view the grid is redrawn just as it was before (10cmx10cm grid, 1cm major, 1mm minor), it just ignored my changes to the settings.
jmaustpc
Postby jmaustpc » Fri Aug 08, 2014 7:44 am
Y Use grid (ticked)
You have to restart FreeCAD, then open the Draft workbench for the new grid to show.
quick61
Postby quick61 » Fri Aug 08, 2014 7:50 am
Now there is something that needs fixing. That and turning the grid on and off. Shouldn't nave to restart FreeCAD for that.
yorik
Site Admin
Postby yorik » Fri Aug 08, 2014 2:01 pm
quick61 wrote:Now there is something that needs fixing. That and turning the grid on and off. Shouldn't nave to restart FreeCAD for that.
True... Can someone please open a ticket on the tracker for that so we don't forget to fix it? Thanks!
quick61
Postby quick61 » Fri Aug 08, 2014 3:37 pm
Sure thing - issue #1671 - Done.
caliston
Postby caliston » Sat Aug 16, 2014 5:18 pm
Thanks folks. I was doubting my sanity there for a minute!
