since I didn't get on with the aeroplane fuselage (see the thread in question), I tackled a clockwork, but I'm already stuck again.
I have to put a sketch on the the top side (that with the axle) of the padded little gear wheel, but when I do that, it always turns to the bottom side
What am I doing wrong again?
P.S.:
If I'm overdoing it with my many questions, don't hesitate to tell me!
I am probably one of your best "customers".
Kind regards
ProApe
Draw a sketch on an object
- Clockwork.FCStd
- (672.96 KiB) Downloaded 14 times
- papyblaise
Re: Draw a sketch on an object
click the "invert" box
but sketch002 is empty
- clock.JPG (27.45 KiB) Viewed 731 times
Sorry, I don't see any "Invert" box when creating a sketch.
What do you mean by "goal sketch002 is empty"?
- Gear.JPG (155.29 KiB) Viewed 657 times
- papyblaise
Sorry : but the sketch is empty
- clock2.JPG (41.66 KiB) Viewed 578 times
Il est vide parce que je n'ai pas su le placer sur le dessus. Pourquoi la roue se tourne-t'elle sur sa face inférieure lorsque je veux créer un sketch sur le dessus? ça c'est toujours un mystère pour moi!
It's empty because I didn't know how to place it on top. Why does the wheel turn on its underside when I want to create a sketch on top? This is still a mystery to me!
- papyblaise
Parceque le Z s'oriente toujours vers le "haut", pour voir le plan sans le pignion pour le cacher , tu vas sur l'arbre et cache le pignon (barre espace)
Because the Z is always oriented "up", to see the plan without the pinion to hide it, you go to the shaft and hide the pinion (space bar)
For the moment I pause this project; it is to complicated to me.
