0.20.1 issue with textures: they are not even applied
I just draw a wrench following a tutorial, to get more practice with FreeCAD
At the end, i wanted to add a texture. But even after have loaded the texture, ti doesn't show really up.
The result is quite crapy.
Please here the animated GIF that shows you the behavior.
However on any project the result is the same and with any texture :-/
The texture I downloaded is this one https://www.goodtextures.com/image/1827 ... ture-18270
______________
Bart R.
Bart R.
Re: 0.20.1 issue with textures: they are not even applied
Please try with a simple Part_Box.
Done. I got the identical result :-/
the crate cube becomes darker ... that's it. No matter which texture I apply ...
NOTE/ in all the cases: if i click on ENVIRONMENT, i see the texture but as reflexes from the environment. but when the environment is not ticked (checked), the object is just darker.
______________
Bart R.
Bart R.
The command works but its results are limited. The texture is projected along the X-axis, which results in a streaky pattern for faces whose normals are perpendicular to that axis.
I have used background.png for the texture.
- background.png (21.97 KiB) Viewed 559 times
- texture_test.png (88.68 KiB) Viewed 559 times
Also with PNG I get the same result. Ok the environment, not-working on the object.
______________
Bart R.
Bart R.
Check the faces whose normals are parallel to the X axis.
Yes they are however even with the cube you have suggested: not any texture applied. On any angle/orientation.
______________
Bart R.
Bart R.
My V0.20 version info:
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Installed mods:
Please here mine
Please note that it's written Windows 10 version 2009 while I have Win 11 21H2 Build 22000.1281 (out of Winver) hence I have not clue where FreeCAD is taking the infos from
OS: Windows 10 Version 2009
Installed mods:
* 3D_Printing_Tools
* CADExchanger
* CurvedShapes 1.0.4
* Curves 0.6.1
* fasteners 0.4.24
* fcgear
* InventorLoader 1.3.0
* kicadStepUpMod 10.16.5
* pcb
* POV-Ray-Rendering
* Render 2022.3.0
* ThreadProfile 1.84.0
* WebTools
______________
Bart R.
Bart R.
