Addon Manager hangs Freecad
NuriEv
Post by NuriEv »
I tend to think that it's likely a result of some weirdness in my setup. Yet I'd like to know if anyone has run into this condition.
Addon manager hangs before it gets done checking the repository, i.e., it becomes unresponsive. Clicking on "Close" for example, crashes and terminates Freecad altogether.
At the point where it hangs, the last message would be
"Getting metadata from macro" ... Dxf to Shape. ... Compund Plus... etc.
This is repeatable every time I try.
Thanks to all for looking at this.
OS: Debian GNU/Linux 11 (bullseye) (KDE/plasma)
Version: 0.21.30988 (Git) AppImage
Hash: 0679c40d26ab2f48ca0f8cd0c34ac3bdbdacec54
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
  * Curves 0.5.11
  * Manipulator 1.4.9
  * Silk 1.0.0
  * BIM 2021.12.0
  * Help 1.0.3
  * workfeature
  * CADExchanger
  * parts_library
  * ose-piping
  * Render.backup1663790588.0453942 2022.2.0 (Disabled)
  * Estimate 0.1.2
  * slic3r-tools
  * Ship 2022.4.11
  * Marz 0.0.26-alpha
  * ArchTextures
  * CurvedShapes 1.0.4
  * POV-Ray-Rendering
  * nurbs
  * MeshRemodel 1.8919.0
  * FEMbyGEN 1.1.0
  * workfeature-macro
  * Render 2022.2.0
chennes
Re: Addon Manager hangs Freecad
Post by chennes »
Can you tell FreeCAD to show log messages in Report View and post the output here?
Chris Hennes
Pioneer Library System
NuriEv
Post by NuriEv »
Thanks for looking
Booting Freecad after an "Addon manager" crash, the report view displays:
10:54:24  NOTICE: Addon "/home/ev/.local/share/FreeCAD/Mod/Render.backup1663790588.0453942" disabled by presence of ADDON_DISABLED stopfile
10:54:40  Recent macros : keyboard shortcut 1 disabled because conflicting with Std_ViewFront
10:54:40  Recent macros : keyboard shortcut 2 disabled because conflicting with Std_ViewTop
10:54:40  Recent macros : keyboard shortcut 3 disabled because conflicting with Std_ViewRight
The contents of the ADDON_DISABLED stopfile is:
This is a backup of an addon that failed to update cleanly so was re-cloned. It was disabled by the Addon Manager's git update facility and can be safely deleted if the addon is working properly.
Please let me know how to get other possibly useful info when necessary.
chennes
Post by chennes »
That output is normal: can you launch the Addon Manager and screenshot the last few lines?
Chris Hennes
NuriEv
Post by NuriEv »
The first shot is the frozen state after about 20min. of wait.
The second shot has some info about the status of the addon manager.
Thirrd is the crash message after closing via the app ui.
Thanks again.
chennes
Post by chennes »
It doesn’t look like log messages are showing in Report View: the Addon Manager is very verbose :). I am not at a computer right now so I can’t tell you the exact path to the setting. No need to wait 20 minutes, the process that is hanging should have gotten killed after 30 seconds of inactivity.
Chris Hennes
NuriEv
Post by NuriEv »
Waiting could have addressed possible latency issues on the git side, and/or elsewhere. Just to cover a probability to some degree.
Anyway the state of hang here, seems to be an endless loop, and it doesn't seem to trigger a kill. I don't know whether there are any error checking for this sort of thing (connection latencies, timeout, whatever) in the code. Unfortunately I probably don't have the skills to track down such particulars in the source.
I'll try earlier appimage builds that have the newer addon manager version. I'll also try different Linux installs.
Thanks for looking, Chris.
NuriEv
Post by NuriEv »
Results are identical for the last few builds of 0.2.1.
Command line start and output:
FreeCAD 0.21, Libs: 0.21R31097 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2022
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
During initialization the error "[Errno 13] Permission denied: ''" occurred in /home/ev/.local/share/FreeCAD/Mod/CADExchanger/Init.py
Please look into the log file for further information
FEMbyGEN Workbench loaded
/home/runner/work/FreeCAD-Bundle/FreeCAD-Bundle/conda/linux/AppDir/usr/share/libdrm/amdgpu.ids: No such file or directory
Addon Manager: Unexpected 0 response from server
  File "/tmp/.mount_FreeCAEX7Xse/usr/Mod/AddonManager/addonmanager_workers_startup.py", line 902, in run
    self.macro.fill_details_from_wiki(url)
  File "/tmp/.mount_FreeCAEX7Xse/usr/Mod/AddonManager/addonmanager_macro.py", line 274, in fill_details_from_wiki
    code = self._fetch_raw_code(p)
  File "/tmp/.mount_FreeCAEX7Xse/usr/Mod/AddonManager/addonmanager_macro.py", line 328, in _fetch_raw_code
    ).format(self.raw_code_url)
KeyError: 'rawcodeurl'
After Killing Freecad following the crash:
/tmp/.mount_FreeCAEX7Xse/AppRun: line 43: 327525 Killed                  ${MAIN} "$@"
chennes
Post by chennes »
Oh, that helps a lot, thanks. It looks like one of the macros being fetched has a bad URL in it, and then my error-handling code has a bug that is crashing the process when that happens. I'll push a fix to the error handling in a minute here, and then we can track down which macro has the bad URL.
Chris Hennes
NuriEv
Post by NuriEv »
Thank you Chris.
You guys rock, and much appreciated.
