Unable to Sweep in Path WB
browntoastjam
Post by browntoastjam »
Hello All,
I have a Bspline path and a sketch object.
I tried to sweep the sketch along the path and can't seem to do it.
The error is "BRepFill_Sweep::BuildEdge"
I have attached a MWE with this post.
Any ideas what I am doing wrong?
OS: Ubuntu 20.04.5 LTS (XFCE/xubuntu)
Version: 0.21.31097 (Git) AppImage
Hash: ccf074008774f1bdfed8fec09ed60e2c0fe77cae
Python 3.10.8, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
  * Assembly4 0.12.3
  * fasteners 0.3.50
  * sheetmetal 0.2.54
  * Defeaturing
  * Curves 0.5.2
  * Behave-Dark-Colors 0.1.1
  * Assembly3 0.11.3
  * kicadStepUpMod 10.16.5
  * PieMenu
  * ProDarkThemePreferencePack 1.0.0
Thanks.
EDIT: Uploaded file again.
testcablewrap.FCStd
(7.67 KiB) Downloaded 10 times
Last edited by browntoastjam on Sat Nov 26, 2022 8:59 pm, edited 2 times in total.
drmacro
Re: Unable to Sweep in Path WB
Post by drmacro »
Empty file..
drmacro
Post by drmacro »
Are you trying to do something like this?
Snip macro screenshot-110475.png (53.97 KiB) Viewed 627 times
There is a handy macro by @mario52 in this thread that makes it pretty easy.
https://forum.freecadweb.org/viewtopic. ... 9&start=40
browntoastjam
drmacro wrote: Sat Nov 26, 2022 8:10 pmEmpty file..
Sorry. Don't know how that happened.
Re-attaching
testcablewrap.FCStd
(7.67 KiB) Downloaded 14 times
browntoastjam
drmacro wrote: Sat Nov 26, 2022 8:22 pm Are you trying to do something like this?
The sweep path isn't as complicated as that.
There are 30 points in the b-spline.
I tried to make another bspline with fewer control points and that seems to sweep fine.
When I remove the last point the sweep sort of succeeds and shows a rather weird shape, so I guess it is something with the B-spline.
browntoastjam
chrisb wrote: Sun Nov 27, 2022 12:14 am When I remove the last point the sweep sort of succeeds and shows a rather weird shape, so I guess it is something with the B-spline.
It may well be the case that the bspline is somehow "incorrect".
I created the bspline with this code:
import numpy as np
import Draft
points=30
zpoints=np.linspace(0,2.6,points)
sketch=FreeCAD.getDocument('MakeCable').getObjectsByLabel('Path')
b=sketch[0].Shape.makeOffset2D(4).discretize(points)
for i,j in enumerate(b):
	j.z=zpoints[i]
spline1 = Draft.make_bspline(b,closed=False)
The path is a 2d sketch, and I offset it and stretch it along the z-axis to make it 3D.
Is there something wrong with this code?
Thanks.
browntoastjam
Here is another similar example that fails.
The text document within the freecad doc has the exact commands used to create the bspline.
testbspline.FCStd
(12.02 KiB) Downloaded 10 times
browntoastjam wrote: Sun Nov 27, 2022 10:55 pm I created the bspline with this code:
If nobody weighs in, you may repost this in the Python subforum.
