FLAT PATTERN SHEET METAL : DIRECTION OF THE ANGLE IN TECHDRAW
LuigiD
Post by LuigiD »
Hello everybody,
I'm newby to use this software (now 0.20.1).
A simple question for many of us:
Imagine I have to make a simple box, I give the sheet (in pdf format) in the hand's man who must
do the job with the flat plat of the box. How can I indicate to him in
the drawing for example 45° degrees upward the first bend, then the second one
90° downward..and so on..
Can someone help me in order to indicate me a good tutorial for this problem?
papyblaise
Re: FLAT PATTERN SHEET METAL : DIRECTION OF THE ANGLE IN TECHDRAW
Post by papyblaise »
Thereby :?:
we do not specify the 90° bends nor the internal radii which are by default equal to the thickness (well, that's how I was taught and practiced for 50 years in my country :!: )
Z.FCStd
(24.3 KiB) Downloaded 6 times
Shalmeneser
Post by Shalmeneser »
Je dirais même plus.
With Create3DDimension031.FCMacro, it's easy to create axonometric view : https://forum.freecadweb.org/viewtopic. ... 14#p639862
Annotation 2022-11-28 115658.jpg (27.55 KiB) Viewed 224 times
