External geometry referenced to sketch geometry is less prone to TNP, but not immune.jmanatee wrote: ↑Mon Nov 28, 2022 5:00 pm Hows is hiding the pad going to help?
The datum plane is not necessary with this example I know I could detach the sketch and accomplish the same thing but the datum plane is an easy way to get a sketch (or multiple) in the correct orientation.
But this doesn't solve my underlying problem. How do I create a sketch while using the external geometry tool but not have it dependent on the external geometry ?
Is there now way around the TNP?
External geometry attached to generated geometry is very prone to TNP. So hiding generated geometry and selecting sketch geometry is better.
Using expressions avoids TNP, when expressions can be used. For example, using a expression for the Attachment offset Z that references Pad.Length moves the sketch to the top of the Pad (assuming it is padded in the Z direction). And there is no TNP, since no geometry (edge, face, vertex) names are used.
The possibility of TNP can be reduced by good modelling techniques, but, it is a side effect in all parametric modellers.
