FreeCAD relabels edges after opening and closing a sketch without modifying it
luekbaja
Post by luekbaja »
When I click into a sketch, Sketch009 for example, and click cancel without doing anything, some edges will get re-labeled. I don't know if that is the correct term but some external edges I reference change and parts break, especially in the last sketch, Sketch027, and it happens consistently. Every time I open and close Sketch009, the 2 external edges in Sketch027 will change seemingly randomly, sometimes to another line, an ellipse, or a b-spline. I have done this 3 times, each time restarting FreeCAD without saving my changes, and it has happened every time I have tested it.
Here is the file:
https://drive.google.com/file/d/1awnRkd ... sp=sharing
OS: Windows 10 Version 2009
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Installed mods:
  * 3DfindIT 1.2.0
  * A2plus 0.4.60e
  * Assembly4 0.12.4
  * ExplodedAssembly
  * fcgear 1.0.0
  * parts_library
Re: FreeCAD relabels edges after opening and closing a sketch without modifying it
I get an error on a full recompute from FCGear, which stops further investigation.
  File "/Users/cb/Library/Application Support/FreeCAD/Mod/fcgear/./freecad/gears/features.py", line 106, in execute
    gear_shape = self.generate_gear_shape(fp)
  File "/Users/cb/Library/Application Support/FreeCAD/Mod/fcgear/./freecad/gears/features.py", line 248, in generate_gear_shape
    r_head = float(fp.head_fillet * fp.module)
<class 'AttributeError'>: 'FeaturePython' object has no attribute 'head_fillet'
06:29:51  Recompute failed! Please check report view.
Did you use the latest version to build it, or was it made with a previous version?
OS: macOS 10.16
Version: 0.21.31035 (Git)
Hash: c8074a972ee233d303e50e5d525aecae09c1cd04
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: C/Default (C)
Installed mods:
  * FC_SU
  * DynamicData 2.46.0
  * freecad.gears 1.0.0
  * FeedsAndSpeeds 0.4.0
  * fcgear 1.0.0
  * fasteners 0.4.16
  * sheetmetal 0.2.57
  * ExplodedAssembly
  * Curves 0.6.1
GeneFC
Post by GeneFC »
I saw the same error.
My version of the gears addon is labeled "freecad.gears 1.0.0". The readout in the first post shows "fcgear 1.0.0".
Where did that come from?
Gene
papyblaise
Post by papyblaise »
it's not a good idea to do the pinion first, it requires a lot of resources and time with each recalculation
during the first search, I get an error sketch and I am blocked
it would have been better to make a total arm then to duplicate it X3 then the pinion
Shalmeneser
Post by Shalmeneser »
:idea:
RC Car _SHALM.FCStd
(530.93 KiB) Downloaded 9 times
Capture d’écran 2022-11-29 162444.jpg (79.51 KiB) Viewed 262 times
luekbaja
Post by luekbaja »
@chrisb I just updated to 0.20.1 and the gear was created with 0.19.something.
luekbaja wrote: Tue Nov 29, 2022 4:07 pm @chrisb I just updated to 0.20.1 and the gear was created with 0.19.something.
You may have to recreate it.
