PolarPattern with Z-axis shift depending on the function of angle
edwilliams16
Re: PolarPattern with Z-axis shift depending on the function of angle
Post by edwilliams16 »
Purely through the Gui, using Lattice2.
The key was to add a custom thetadeg property to a Part Cylinder and couple it to its Placement via expressions. Then make a Lattice2 paraseries in the thetadeg parameter.
Screen Shot 2022-11-30 at 8.48.19 AM.png (48.99 KiB) Viewed 891 times
wavyholes.FCStd
(232.67 KiB) Downloaded 15 times
drmacro
Post by drmacro »
Just a left field comment. The Nodes workbench can also do this quite nicely.
edwilliams16
Changing the technique slightly into a way that nicely generalizes to any situation where we want to populate a single-parameter family of placements with an object.
  • Create a custom Placement
  • Right-click in its data field and create a new float property.
  • Use expressions in the Placement fields to describe the location and orientation of the Placements as a function of your new parameter.
  • Select the Placement and then click Lattice2|Series Features|Paraseries.
  • In the paraseries properties create the parameter series using the generator, by listing values ,or by extracting from a spreadsheet
  • Set ParameterRef to Placment.yourParameterName Directly - not in the Expression Editor!
  • ParameterType is float
  • Turn on recomputes.
In the example, the parameter Name is Base_t, corresponding to angle. The angles are generated in - 20 values from 0 to 360 - not including 360.
The Parametric placement is:
You can populate the paraseries with objects, using Lattice2|Populate with copies.
customplacementarray.FCStd
(15.67 KiB) Downloaded 14 times
Screen Shot 2022-11-30 at 10.45.04 AM.png (18.46 KiB) Viewed 844 times
Screen Shot 2022-11-30 at 10.43.55 AM.png (43.79 KiB) Viewed 844 times
Screen Shot 2022-11-30 at 10.39.53 AM.png (33.29 KiB) Viewed 844 times
JackkDBA
Post by JackkDBA »
Many thanks to all of you for help :)
I will learn Lattice2 workbench from the videos to understand what's going on.
Best regards,
Jacek
edwilliams16
Mangojelly has a good youtube series on Lattice2 but I’m not sure he specifically covers paraseries.
edit:
@JackkDBA
Lattice2's documentation is at https://github.com/DeepSOIC/Lattice2/wiki. Some examples in the forum: https://forum.freecadweb.org/viewtopic.php?f=3&t=67968 https://forum.freecadweb.org/viewtopic. ... 09#p610909
JackkDBA
Post by JackkDBA »
edwilliams16 wrote: Wed Nov 30, 2022 8:51 pmIn the example, the parameter Name is Base_t, corresponding to angle.
I can't figure out where the Base_t parameter is defined and where is the "t" property came from:
Best regards,
Jacek
edwilliams16
@JackkDBA
From right clicking in Custom’s data field and adding a new property.which you name t in the group Base.
JackkDBA
Post by JackkDBA »
edwilliams16 wrote: Sun Dec 04, 2022 1:18 pm @JackkDBA
Maybe I am clicking in wrong place but I don't see an option similar to "Add property" after right-click on Custom's data (empty field below "Placement Choice") :roll: :
Best regards,
Jacek
edwilliams16
Right click, set "Show All'.
Right Click, 'Add Property'
I think I have 'Show All' as my default somewhere.
Vincent B
Post by Vincent B »
Trying to do with ParametricCurve but can't give the right orientation right now. :roll:
Special_polarpatern.FCStd
(20.91 KiB) Downloaded 14 times
