[Solved] TechDraw template issues? (directory needed write permission access)
TristanGoss
Post by TristanGoss »
Hi there, I hope you can help me? I am using FreeCAD 0.20.1. When in the TechDraw workbench I get the following message when loading the default template or when selecting an alternate template:
"The error message is: Template not set for Page
15:00:18 Traceback (most recent call last):
<class 'OSError'>: Cannot copy file from C:/Program Files/FreeCAD 0.20/data/Mod/TechDraw/Templates/A3_LandscapeTD.svg to /A3_LandscapeTD.svg"
However, if I navigate to C:/Program Files/FreeCAD 0.20/data/Mod/TechDraw/Templates/A3_LandscapeTD.svg the A3_LandscapeTD.svg file is there, and I can open it using Google Chrome.
I thank you in advance, Tristan
Reason: Added note to title thread
wandererfan
Re: TechDraw template issues?
Post by wandererfan »
TristanGoss wrote: Tue Nov 29, 2022 1:07 pm "The error message is: Template not set for Page
Not sure why it is trying to write to "/", should be writing to a temporary directory. Do you have write permission for the root directory ("/" on current drive)?
Syres
Post by Syres »
Just to add to wandererfan's question, what is the TMP (not TEMP) environment variable set to using:
set tmp
at a Command Prompt
TristanGoss
Thank you, after the IT guys have granted write access the C:\ route directory my problem is solved. Much appreciated!
efferre
Re: [Solved] TechDraw template issues? (directory needed write permission access)
Post by efferre »
I have found the same problem when using freecad 0.21.0 under Windows. From the python console inside freecad I get
>>> import os
>>> os.getenv('tmp')
'C:\\Users\\fabio\\AppData\\Local\\Temp'
>>> os.getcwd()
'C:\\Program Files\\FreeCAD 0.21\\bin'
>>> os.chdir('/')
>>> os.getcwd()
'C:\\'
>>> f=open('test.free','w')
PermissionError: [Errno 13] Permission denied: 'test.free'
But the user can write directly in C:\ outside freecad
efferre
Post by efferre »
wandererfan wrote: Tue Nov 29, 2022 1:28 pm
As you can see from the previous post, it seems that I am not able to write in "/" from freecad but the user has write access to C:
onekk
Post by onekk »
efferre wrote: Wed Aug 23, 2023 9:02 pm
On Windows directory permissions have to be managed carefully, you are the user but freecad could result in a different "user" result in the write denial.
There are around if you search as a general problem like "windows directory permissions" ways to check the permissions that could reveal that maybe some permissions are not set correctly.
I'm not a Window expert but the problem is known even in other softwares
Regards
Carlo D.
- Various other stuffs.
efferre
Post by efferre »
onekk wrote: Wed Aug 23, 2023 10:22 pm On Windows directory permissions have to be managed carefully, you are the user but freecad could result in a different "user" result in the write denial.
Regards
Carlo D.
I am a Linux user where everything works smoothly :-) Probably there is an issue with permissions but I cannot find a solution. Nothing is written in the docs.
I think the real issue to investigate is why freecad tries to write to "/" instead of
os.getenv('tmp')
Syres
Post by Syres »
@wandererfan Thinking out loud here, would it be possible to use FileInfo::getTempFileName rather than QTemporaryFile for the Template temp store, or have you been down this rabbit hole previously?
wandererfan
Syres wrote: Thu Aug 24, 2023 1:06 am Thinking out loud here, would it be possible to use FileInfo::getTempFileName rather than QTemporaryFile for the Template temp store, or have you been down this rabbit hole previously?
AFAIK, the only place TechDraw uses QTemporaryFile is when you press the Export Svg button. From what I can see from the posts, this case doesn't involve Svg Export.
TechDraw does indirectly cause a write to a temporary directory because it uses PropertyFileIncluded for the template file. If PropertyFileIncluded fails to write the temporary file, then the Template would not be created properly, which would cause the "Template not set for Page" message.
I don't think PropertyFileIncluded uses QTemporaryFile, though.
