Unable to cut .svg extrusion into basic shape
skatemax9
Post by skatemax9 »
Hey, all!
Just like many other posts that I've read, I am new to FreeCAD and am having trouble getting a logo extrusion cut into a basic cylinder. After importing the .svg file of my logo, it appears as over a hundred paths. After scaling it down to my required size and converting into a single sketch, I extruded it into a 3D shape and aligned it with my basic cylinder. The various tutorials and videos I have reviewed each have slightly different methods for cutting the extrusion into the shape, but each time it fails. Any help would be greatly appreciated! The svg, pictures, and system info are below.
OS: macOS 10.16
Version: 0.20.1.29410 (Git)
Branch: (HEAD detached at 0.20.1)
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Locale: C/Default (C)
Station 7 Logo.FCStd
(414.04 KiB) Downloaded 14 times
Screen Shot 2022-11-30 at 4.38.43 PM.jpeg (673.86 KiB) Viewed 458 times
kMN6py01.svg
(21.17 KiB) Downloaded 12 times
Re: Unable to cut .svg extrusion into basic shape
Hi and welcome to the forum!
You should upload the FreeCAD file as well, so that not everyone has to start from scratch.
skatemax9
Post by skatemax9 »
Got it! Thank you!
edwilliams16
Post by edwilliams16 »
Part|Check Geometry on Extrude says Wire847 and Wire848 are self-intersecting - so they can't be extruded.
In the python console, I put
shp = ActiveDocument.getObject("Extrude").Shape
Part.show(shp.Wires[846].copy())
Part.show(shp.Wires[847].copy())
Python indexes from 0, wire names from 1.
Screen Shot 2022-11-30 at 1.25.32 PM.png (16.06 KiB) Viewed 390 times
This identified the problem. I went into Sketch, dragged the offending vertex so I got a non-intersecting closed loop and saved.
I increased the extrusion length to 5.1 mm so it stuck up above the Fillet and Part|cut.
Resulting file too big to upload.
Screen Shot 2022-11-30 at 1.51.11 PM.png (99.81 KiB) Viewed 390 times
papyblaise
Post by papyblaise »
with me it works perfectly, the only problem is that the upper faces are coplanar
Change the height of the cylinder, or of the logo, and make the fillets at the end
Shalmeneser
Post by Shalmeneser »
:!: you can see the problem here with this face coming from nowhere (= from an 'error' in the path).
Annotation 2022-12-01 113857.jpg (19.53 KiB) Viewed 279 times
