Offsetting sketch to global planes.
drmacro
Re: Offsetting sketch to global planes.
Post by drmacro »
edwilliams16 wrote: Thu Dec 01, 2022 6:11 pm So using the existing code I see a couple of workarounds to create offset sketches.
  • Drag your current model into an outer Part container and attach your new sketch to its coordinate system.
  • Create a Part 'reference cube', select the face on the desired plane and create your sketch with the default FlatFace attachment.
Either way, you are then free to offset the sketch from your chosen global plane.
In this forum we typically advocate attaching sketches to offset global planes to avoid TNP, but I don't think we explain that in Part workbench this is not as straightforward as it might seem. We also chide people for unnecessarily wrapping their models in Part Containers, when on occasion this might be appropriate even if no assembly operations are anticipated.
The Attachment to base planes, in PD, is attaching to the LCS (the Origin object) of the Body. It in turn is "attached" to the global. The Origin object in a Body is static, thus attaching to it is what is advocated.
In the case of a Sketch outside a Body, the Placement is referenced to the global axis. The global axis is static.
When the sketch is create (outside a Body) with the planes offered in the creation dialog and the user selects other than XY, then there is a cognitive issue when the user needs to move the sketch normal to the sketch local Z axis.
Obviously there are uses for the Std_Part. I think most of the "chiding" is making it clear the Std_Part is not a prerequisite for a Body or anything else.
edwilliams16
Post by edwilliams16 »
drmacro wrote: Thu Dec 01, 2022 7:14 pm
Agreed. And as Chrisb and I have pointed out, the cognitive issue gets more severe if the Attachment Offset is more complicated than a translation along an axis. That motivated the OP.
heron
Post by heron »
edwilliams16 wrote: Thu Dec 01, 2022 1:00 am I have work-arounds, but is there really no direct way to attach a sketch to the global coordinate system? This has been bugging me for a while.
Hello, sorry for the late reply, but I also found this problem and my workaround is to add a LCS:
App.ActiveDocument.addObject("PartDesign::CoordinateSystem", "Zero")
This way I already have my "GCS" to attach my sketch.
edwilliams16
heron wrote: Wed Dec 07, 2022 5:16 pm
Good idea.
Via the Gui, apparently one is forced to put the LCS in a Body, then pull it out and delete the Body . It would be much nicer, if creating a Part Design| LCS gave the option of not putting it in a body.
Screen Shot 2022-12-07 at 8.14.18 AM.png (48.87 KiB) Viewed 732 times
edwilliams16
Which gave me an idea that works in the Gui.
Create a default Lattice2|Lattice Placement|Single Custom Placement. It can be used as a global LCS to which sketches can be attached, in the same way as an LCS created in the python console
Screen Shot 2022-12-07 at 8.28.53 AM.png (48.55 KiB) Viewed 720 times
Screen Shot 2022-12-07 at 8.28.33 AM.png (12.42 KiB) Viewed 720 times
globaloffset.FCStd
(7.67 KiB) Downloaded 6 times
heron
Post by heron »
edwilliams16 wrote: Wed Dec 07, 2022 6:31 pm Which gave me an idea that works in the Gui.
Oh, if you need to do it in the Gui, this LCS tool is in Manipulator WB
Here are macros to create DatumGeometry and LCS globally: https://forum.freecadweb.org/viewtopic. ... 40#p304740
drmacro
Post by drmacro »
I'm actually amazed how little known these macros are:
https://github.com/sebasg84/planeFromFace
They allow the creation of sketches on any face, but with attachment offsets.
Select a face, run the macro and the sketch is attached to the base plane with the attachment offset of the selected face.
And repairing after the model has been updated.
Select the new face and the sketch, run the macro and it repairs the offset.
edwilliams16
Some handy stuff there, including one-liners for the console:
App.ActiveDocument.addObject('PartDesign::CoordinateSystem')
App.ActiveDocument.addObject('PartDesign::Point')
App.ActiveDocument.addObject('PartDesign::Line')
App.ActiveDocument.addObject('PartDesign::Plane')
edwilliams16
I wasn't totally satisfied with the solutions provided, so I wrote a Macro and put it in my Part toolbar. It will create a Sketch attached to a global (XY, YZ, XZ) plane that can then be offset.
Screenshot 2022-12-11 at 2.25.03 PM.png (68.03 KiB) Viewed 459 times
Screenshot 2022-12-11 at 2.26.00 PM.png (82.75 KiB) Viewed 459 times
''' Macro to create a sketch attached to a global plane in the root coordinate system
    V0.1  12/11/22 edwilliams16'''
from PySide.QtGui import QWidget, QVBoxLayout, QComboBox, QPushButton, QLabel
from PySide import QtCore
class PlaneChooseWindow(QWidget):
    def __init__(self):
        super(PlaneChooseWindow, self).__init__()
        layout = QVBoxLayout()
        label = QLabel('Attach Plane')
        layout.addWidget(label)
        self.dg = QComboBox()
        self.dg.addItems(['XY', 'YZ', 'XZ'])
        layout.addWidget(self.dg)
        self.ok = QPushButton("OK", self)
        layout.addWidget(self.ok)
        QtCore.QObject.connect(self.ok, QtCore.SIGNAL("pressed()"), self.ok_clicked)
        self.cancel = QPushButton("Cancel", self)
        layout.addWidget(self.cancel)
        QtCore.QObject.connect(self.cancel, QtCore.SIGNAL("pressed()"), self.cancel_clicked)
        self.setLayout(layout)
        self.show()
    def ok_clicked(self):
        #print("OK Clicked")
        doc = FreeCAD.ActiveDocument
        mapto = self.dg.currentText()
        lcs = doc.addObject('PartDesign::CoordinateSystem')
        lcs.Visibility = False
        sketch = doc.addObject('Sketcher::SketchObject', 'Sketch')
        sketch.MapMode = 'Object' + mapto
        sketch.Support = lcs
        doc.recompute()
        self.close()
    def cancel_clicked(self):
        self.close()
mywin = PlaneChooseWindow()
