second post work bench drawing plane help
mack5
Post by mack5 »
hi
i need help using the part wb drawing plane. look at my test drawing, how do i
1 make 2 drawing planes that are parallel to each other one on the top, one the bottom? i trying to rotate the plane around the y axis.
2 how do i model 4 lugs 2 on each surface? i been trying but not having any success.
thanks
OS: Windows 10 Version 2009
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Installed mods:
  * freecad.gears 1.0.0
nctest.FCStd
(116.73 KiB) Downloaded 13 times
drmacro
Re: second post work bench drawing plane help
Post by drmacro »
No need for Datum planes.
Screenshot from 2022-12-01 18-53-57.png (126.46 KiB) Viewed 674 times
nctest-mac.FCStd
(108.07 KiB) Downloaded 9 times
mack5
Post by mack5 »
hi
thanks
i am asking how to make 4 lugs starting on the outsides surfaces of the cylinder about 5 mm pad one in the front, one at the rear of the cylinder.
. so the inside of the cylinder is open. i thank i need a drawing plane.
then i need to rotate the plane on the y axis's to the horizontal position move the 2 planes with one on the top and one on the bottom of the outside of the cylinder. then draw the circles and pad them.
the final model should 4 lugs 2 on the top 2 on the bottom. i hope this is clear?
thanks :D
drmacro
Post by drmacro »
Two different ways, no Datum planes.
Again...no need for Datum planes... :mrgreen:
nctest-mac-2.FCStd
(92.32 KiB) Downloaded 10 times
nctest-mac-1.FCStd
(50.98 KiB) Downloaded 7 times
Snip macro screenshot-bf7b83.png (140.34 KiB) Viewed 481 times
mack5
Post by mack5 »
hi
when trying to draw on a curve surface, i get a error message that said that you can not draw on a curve planar(?)r surface not a direct quote. so i first draw flat surface then draw the circle now, i will try it again. i may be trying to hard at this. i forgot about the array command.
many thanks :D
Bance
Post by Bance »
DO NOT place sketches on surfaces. Instead use std planes and offset them.
drmacro
Post by drmacro »
I didn't try the simplest method, which results in round rods, because I didn't know the Pad Up to Face had been improved. :mrgreen:
nctest-mac-3.FCStd
(191.64 KiB) Downloaded 11 times
Snip macro screenshot-1700e5.png (103.11 KiB) Viewed 332 times
