[SOLVED] PARTDESIGN AdditivePipe not working
kurti99
Post by kurti99 »
Hi
I would need your help again.
take a look at the attachment studycadcam ex1088.
Who knows why the last additivepipe doesn't work. You can see the handle in the edit window, but not anymore
Part->Checkgeometry is okay.
Partdesign->ValidateSketch is not okay, there are 2 wrong vertexes, but i have no idea what the problem is
thanks in advance for your help
OS: Windows 10 Version 2009
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Installed mods:
  * Assembly4 0.12.4
Ex 1088 studycadcam.FCStd
(190.54 KiB) Downloaded 10 times
papyblaise
Re: PARTDESIGN AdditivePipe not working
Post by papyblaise »
there can only be one object in the Body, you make the small handle in another Body
(153.55 KiB) Downloaded 8 times
kurti99
Post by kurti99 »
hi papyblaise,
yes, you're right - that's the reason.
Q: have you an idea how i can find the reason of the 2 wrong vertexes after validate the sketch of the path ?
thank you !
Shalmeneser
Post by Shalmeneser »
kurti99 wrote: Fri Dec 02, 2022 6:03 pm Q: have you an idea how i can find the reason of the 2 wrong vertexes after validate the sketch of the path ?
Because the sketch is 'opened' and not 'closed' which is normal for a Pipe path.
Shalmeneser
:idea:
StudyCADCam 1088_SHALM.FCStd
(209.17 KiB) Downloaded 13 times
Capture du 2022-12-02 23-34-53.png (67.04 KiB) Viewed 332 times
kurti99
Post by kurti99 »
@Shalmeneser thank you - best solution
