Would greatly appreciate if a good Samaritan is willing to look at my file and advise on how to figure out what constraints are needed.
It looks like all of the vertices are green when I click "find DOF", but lots of the edges are not green but I have not figured out why.
Any advice?
Seeking tips on identifying missing constraints in Sketch
Re: Seeking tips on identifying missing constraints in Sketch
You have multiple instances of 0 mm dimensional constraints,, it is much better to geometric constraints and avoid 0 mm constraints.
This sketch has way too many constraints. You should use multiple sketches.
There is some symmetry that you could take advantage of a simplify/reduce the constraints making each sketch easier to read and maintain.
To find missing coincident constraints, use the Sketch Validate tool or just grab lines and attempt to move them.
- Screenshot from 2022-12-04 20-13-17.png (16.04 KiB) Viewed 705 times
Thanks DrMacro!
I will have another go at it starting with a symmetry line and change the 0mm distances to vert or horizontally equal.
I will also do some more studying to see if I can do the same 2 objects in 2 separate sketches and then constrain them together afterwards - this was my preference anyway but I gave up and thought it would be easier if I did it all in the same sketch. I now see that it maybe isn't easier.
Thanks for the advice - I will persist!
- papyblaise
by dividing into 3, it goes much better, I used your sketch as master without trying to improve the rating
there are many unclosed points
- Lego.FCStd
- (122.85 KiB) Downloaded 10 times
- Lego.JPG (25.25 KiB) Viewed 626 times
It sounds like you may be confusing "same position" with "connected". Two points with a relative distance of 0 mm are not automatically connected. That is why there are so many DOFs left.ManOfScience wrote: ↑Mon Dec 05, 2022 5:19 am I will have another go at it starting with a symmetry line and change the 0mm distances to vert or horizontally equal.
Rather than set a distance or an equal constraint you need to make sure that intended connections are really connected. Use "coincident", "tangent", etc.
Gene
- Shalmeneser
- Lego Shelf Rings_SHALM.FCStd
- (90.67 KiB) Downloaded 12 times
- Capture du 2022-12-05 22-23-34.png (22.47 KiB) Viewed 482 times
