I want to give covering sketchs to my 2D sketch
ismetacar
Post by ismetacar »
Hello guys, I'm new in here and try to learn Freecad! I have some issue that I don't know how to explain but I will do my best. I have a 2D sketch and I want to enlarge that sketch but there is a catch... It must be 2mm to all direction so 2. sketch will looks like covering the 1. sketch (with 2 mm distance) I tried my best to find solution to my problem but I couldn't. Can you explain me to how to do it or can you give me some advices. Thanks a lot already!
My FreeCad Version is 0.20.1
OS: Windows 10 Version 2009
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Locale: Turkish/Turkey (tr_TR)
NewJoker
Re: I want to give covering sketchs to my 2D sketch
Post by NewJoker »
This is called offset. It's not implemented yet but you can use:
- SketcherOffset macro: https://github.com/FreeCAD/FreeCAD-macr ... et.FCMacro
- Part Offset2D tool
- Draft Offset tool
adrianinsaval
Post by adrianinsaval »
Or make a subshapebinder of the sketch and use it's offset property if you are using Part Design.
drmacro
Post by drmacro »
adrianinsaval wrote: Mon Dec 05, 2022 8:12 pm Or make a subshapebinder of the sketch and use it's offset property if you are using Part Design.
Just a side note. Subshapebinder works outside of Part Design.
But a Shapebinder will only work in Part Design.
ismetacar
Post by ismetacar »
Thank you guys I figured it out thanks to you God bless you!
