Disrupted profile with Additive Pipe
BartR
Post by BartR »
FreeCAD Version
NOTE: the operating system is NOT windows 10 but Windows 11 Pro 64 bit
Version 21H2 build 22000.1281
OS: Windows 10 Version 2009
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Installed mods:
  * 3D_Printing_Tools
  * ArchTextures
  * CADExchanger
  * CurvedShapes 1.0.4
  * Curves 0.6.1
  * fasteners 0.4.24
  * fcgear
  * InventorLoader 1.3.0
  * kicadStepUpMod 10.16.5
  * pcb
  * POV-Ray-Rendering
  * Render 2022.3.0
  * ThreadProfile 1.84.0
  * WebTools
Here what's occurring each time.
When I'm completing the path, a small aperture is created into it, disrupting everything. Not any idea "why".
Here the project please:
https://drive.google.com/file/d/12ngCfx ... sp=sharing
______________
Bart R.
BartR
Re: Disrupted profile with Additive Pipe
Post by BartR »
I also remade (just finished few minutes ago) the base sketch which is the path of that object.
And I constrained the round corners to be tangent to the sides.
but I still get this issue and I have not clue what I'm doing wrong.
______________
Bart R.
papyblaise
Post by papyblaise »
the constraints are badly made: there are rays which do not have a tangent connection, but angular
the addPipe is always perpendicular to its path so if the path is angular, the Pipe will be open
DISRUPTED.FCStd
(198.68 KiB) Downloaded 7 times
BartR
Post by BartR »
papyblaise wrote: Mon Dec 05, 2022 12:55 pm the constraints are badly made: there are rays which do not have a tangent connection, but angular
Thank you so much. Evidently also in the changes I have mande some minute ago, I did something wrong again.
I will remake it giving priority to tangency and then fixing the other measures.
______________
Bart R.
papyblaise
yes, it is the rule (unwritten, and undocumented by the relentless of the video) to make the geometric constraints first, and the dimensions after
Shalmeneser
Post by Shalmeneser »
:idea:
KISS ! keep it stupidly simple.
XY-plane for the opening face.
Don't know why your file is so heavy.
Capture du 2022-12-05 23-15-58.png (41.72 KiB) Viewed 479 times
Disrupted_SHALM.FCStd
(446.24 KiB) Downloaded 13 times
papyblaise
je dirai même plus : cause the theared Hole
Shalmeneser
papyblaise wrote: Tue Dec 06, 2022 10:24 am ' cause the theared Hole
But why ? It seems doing a hole longer than needed do not change the file size.
Or because it's doing 2 holes far from each other inside the same action ?
