Create a loft through a union
nicokid
Post by nicokid »
Hi forum,
I have to create a hole through a union. I thought of using the part design loft tool and two sketch mapped on union faces (start_hole and end_hole).
The problem is that it is not possible to select the union as the active body and so I cannot use the loft tool :cry:
I have attached my drawing.
Any suggestions? Thanks.
Nicola.
OS: Ubuntu 20.04.5 LTS (ubuntu:GNOME/ubuntu)
Version: 0.21.
Branch: unknown
Hash: 10e9e3b9b54225ecb7f0c3ae9df40552151d7cc2
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.2
Locale: Italian/Italy (it_IT)
Installed mods:
  * fasteners 0.4.23
lamellar_pack_phbg_v1.FCStd
(147.37 KiB) Downloaded 21 times
Re: Create a loft through a union
You should not mix Part and PartDesign if it is not necessary. This can be done completely either in Part or in PartDesign, whatever suits you better.
Bance
Post by Bance »
Your file is a mess, read this:-
Part and PartDesign
papyblaise
Post by papyblaise »
the operations are not in the correct order,
and the merge does not use the correct objects
you have to make a new Body and drag the fusion and the 2 sketches in it, you have to make a new sketch for the path and make a subtractivPipe
check the diameters, in my opinion you made a mistake in the one on the flange side, if the 2 are equal (as I did) one is enough
collector.FCStd
(203.37 KiB) Downloaded 13 times
nicokid
[Soved] Create a loft through a union
Post by nicokid »
I followed chrisb's suggestion and did everything with part design. Took me a while but something came out :D Thanks.
I've always had a lot of confusion with part and part design. I have read the explanation in Part and PartDesign. Now it's a little clearer. Thanks Bance.
Unfortunately I hadn't seen papyblaise's message with the solution already done :cry: :cry: But thank you anyway :D
This is my solution.
(429.39 KiB) Downloaded 10 times
Re: [Soved] Create a loft through a union
nicokid wrote: Fri Dec 09, 2022 12:44 am This is my solution.
Even if someone here has provided a model, it is a good idea to do it yourself. And perhaps not only once but several times, possibly with different flavours, until each of the flavours goes fluently. And then you can decide which path is best for you.
Your model still shows that you still work like being in Part workbench. The booleans in PartDesign are rarely used, because they are rarely necessary and make a model more difficult to understand.
In your case you should add both features, i.e. the pipe and the subtractive cube, from the boolean directly at that place in the tree.
Shalmeneser
Post by Shalmeneser »
:idea:
lamellar_pack_phbg_SHALM.FCStd
(253.53 KiB) Downloaded 10 times
nicokid
Post by nicokid »
chrisb wrote: Fri Dec 09, 2022 4:25 am
I removed the boolean right before your post :D
Thank you.
lamellar_pack_phbg_v3.FCStd
(441.84 KiB) Downloaded 8 times
