[SOLVED] Only part of sketch rotates
fr33cadtom
Post by fr33cadtom »
See Attached file. I am trying to rotate both parts of the sketch to be a 1/2 sphere and a ring, but only the 1/2 sphere gets generated.
Any ideas?
Thanks
Tom
OS: Windows 10 Version 2009
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Installed mods:
  * A2plus 0.4.59e
  * Assembly4 0.12.4
  * CubeMenu
  * fasteners 0.4.16
  * fcgear 1.0.0
  * Pyramids-and-Polyhedrons
  * ThreadProfile 1.84.0
Rotate Test.FCStd
(11.04 KiB) Downloaded 20 times
jmanatee
Re: Only part of sketch rotates
Post by jmanatee »
They are not connected. All parts of a sketch must connect
Rotate Test.FCStd
(15.17 KiB) Downloaded 17 times
GeneFC
Post by GeneFC »
jmanatee wrote: Tue Dec 06, 2022 2:56 am They are not connected. All parts of a sketch must connect
Two comments:
Sketches can be used for many purposes. There is no general requirement that all parts of a sketch must connect. Yes, in this case the two parts of the sketch must be connected in order to support the revolve operation. But as a general rule that is too restrictive.
Please use a new (modified) name for any FCStd file posted. It can be very confusing if both the old file and the corrected file have the same name.
Gene
fr33cadtom
All,
Thank you for your help. I understand the issue.
I have revised my part to have a block under it and am successfully adding the portions I am interested in on top of the block. After I finish, I will export it for 3d printing. In the "slicer" program, I will removed the block and print the rest.
Thanks again,
Tom
