Screws with a pitch greater than 0.243 inch
Frotz
Post by Frotz »
I'm trying to model a wooden screw of 1-inch diameter with 4 TPI, which translates to 0.25-inch pitch. When I create such a screw with the Fasteners workbench, I saw where the threads would go, but the cuts didn't get made. Playing around with this, I discovered that the greatest pitch I could get was 0.245-inch. Going to 0.246-inch would give me the wacky non-threading. What's going on?
Below is a screenshot of a 1-inch diameter rod threaded at a pitch of 0.245 on the top and 0.246 at the bottom:
OS: Debian GNU/Linux 11 (bullseye) (MATE/mate)
Version: 0.21.31189 (Git)
Build type: Unknown
Hash: 2131a4732b00a65aeac0d3366db575df50c00364
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.1
Installed mods:
  * Assembly3 0.11.3
  * Pyramids-and-Polyhedrons
  * sheetmetal 0.2.58
  * freecad.gears 1.0.0
  * A2plus 0.4.60b
  * fasteners 0.4.23
  * Manipulator 1.4.9
badthreads.FCStd
(978.53 KiB) Downloaded 16 times
Re: Screws with a pitch greater than 0.243 inch
Sorry for not answering your question, but for a wooden thread I would rather use a trepezoidal shape for the thread and thus do it manually with a helix.
Shalmeneser
Post by Shalmeneser »
Same problem (a recent Fastener wb is needed. an old one breaks when recomputed)
OS: Windows 10 Version 1909
Version: 0.21.30265 (Git)
Hash: c35244e74f326a04c5bcab31e984742db582ac78
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
Locale: French/France (fr_FR)
Installed mods:
  * fasteners 0.4.25
  * sheetmetal 0.2.59
Frotz
Post by Frotz »
Shalmeneser wrote: Wed Dec 07, 2022 10:20 am Same problem (a recent Fastener wb is needed. an old one breaks when recomputed)
Installed mods:
  * fasteners 0.4.25
  * sheetmetal 0.2.59
I updated the Fasteners WB and now when I specify a pitch of 0.25-inch straight away, I get an error of
<Part> ViewProviderExt.cpp(1267): Cannot compute Inventor representation for the shape of Unnamed#ThreadedRod: Bnd_Box is void
Specifying a pitch of 0.245 and 0.246 give me the same problems as I described before. Interestingly, if I increase the screw's diameter to 2 inches, a pitch of 0.25 is accepted. The maximum pitch for that was 0.491.
Build type: Unknown
Installed mods:
  * Assembly3 0.11.4
  * sheetmetal 0.2.59
  * A2plus 0.4.60f
  * fasteners 0.4.25
  * Manipulator 1.4.9
Roy_043
Post by Roy_043 »
There have been update issues with the Fasteners workbench. In some case you first have to manually delete the Fasteners installation folder.
papyblaise
Post by papyblaise »
wooden 6x80
6x80 à bois.JPG (14.96 KiB) Viewed 599 times
6x80 à bois.FCStd
(568.44 KiB) Downloaded 9 times
Frotz
Post by Frotz »
papyblaise wrote: Thu Dec 08, 2022 1:33 pm wooden 6x80
I'm sorry. The kind of screw I'm trying to model is a wooden rod with threads cut into it -- not a metal screw intended for driving into wood. I'll keep this sample in mind because I've wanted to model wood screws now and then, but have so far just ignored them in my modeling.
Frotz
Post by Frotz »
chrisb wrote: Wed Dec 07, 2022 9:42 am Sorry for not answering your question, but for a wooden thread I would rather use a trepezoidal shape for the thread and thus do it manually with a helix.
I figured that the threads generated by the Fasteners workbench would be close enough for my purposes since I was planning to use an off-the-shelf tap and die designed for wood.
Frotz
Post by Frotz »
Roy_043 wrote: Thu Dec 08, 2022 9:29 am There have been update issues with the Fasteners workbench. In some case you first have to manually delete the Fasteners installation folder.
Done:
Frotz wrote: Sat Dec 10, 2022 2:22 am I figured that the threads generated by the Fasteners workbench would be close enough for my purposes since I was planning to use an off-the-shelf tap and die designed for wood.
That means, that the thread is used mainly for cosmetic reasons. In that case you may have a look at the Thread for Screw Tutorial, with different suggestions for fake screws. They are way more efficient, which can be significant with big models.
