When I click on pocket I see the object. When I click on lug, I also see the object. However, I cannot see them both - the lug should be in the pocket's object.
What am I doing wrong?
TIA
Unable to view object
- 1.png (77.65 KiB) Viewed 531 times
- Shalmeneser
Re: Unable to view object
File ? Version (link in the red banner) ?
This looks as if the last pad is not connected to the rest. As this violates the single solid rule, one of the two solids is discarded.
Ok, I just cannot get the screw support at the box's corners. Here's the code:
https://ebolisa.net/images/box_parametric.zip
Please attach such files directly as FCStd file here without the backup.
Your file doesn't include the the final pad. If I add it, I see the same issue as you do. As a first workaround you can use for the Pad the Type=TwoLengths, with a tiny second length of e.g. 0.1mm.
I will investigate this further.
The problem was your invalid sketch (here already fixed):
BTW: repeated dimensions always have a bad smell. Better replace all but one with geometric constraints (may need additional construction geometry).
The inner circle must not touch the outer borders.BTW: repeated dimensions always have a bad smell. Better replace all but one with geometric constraints (may need additional construction geometry).
