Good Morning Forum,
please help with this project - when I unfold this 1 mm thick Sheetmetal, it unfolds but is missing the side end bends of 10 mm.
I have unfolded it from top and bottom view, with the same results.
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: English/South Africa (en_ZA)
Regards
Fritz Schnelle
South Africa
Sheetmetal unfold incorrectly
- Potato Griller.FCStd
- (309.41 KiB) Downloaded 15 times
- papyblaise
Re: Sheetmetal unfold incorrectly
it's very annoying: I can't unfold a 60° angle either
I finally got my first bug since I've been on this forum
- Shalmeneser
True, there is a problem before the 1st pocket if you want to unfold.
You should bend multiple 'faces' with the same feature.
- Annotation 2022-12-09 111758.jpg (64.77 KiB) Viewed 565 times
- Potato Griller_SHALM.FCStd
- (438.65 KiB) Downloaded 11 times
- papyblaise
je dirai même plus
I don't like to stay on a failure, redoing it in another flow, it works
- grille patates.FCStd
- (254.25 KiB) Downloaded 13 times
- grille patates.JPG (42.64 KiB) Viewed 518 times
Good Morning,
thanks for the suggestions, I have used them and it has worked successfully.
Regards
Fritz Schnelle
Regards
Fritz Schnelle
