Hello all,
I have been failing to merge the three sketches in the attached file. I created a composite to represent what I want the sketch to look like in the end. Anyone know how to merge all three sketches to look like the Composite does?
Help Merging all three sketches
- tiara_2.FCStd
- (96.43 KiB) Downloaded 12 times
- Shalmeneser
Re: Help Merging all three sketches
Why do you want to 'merge' sketches ? (don't know what it means btw).
Your 3 sketches are overly complex. You should use KISS methodology : Kee it stupidly simple !
- tiara_SHALM.FCStd
- (236.48 KiB) Downloaded 8 times
- Capture d’écran 2023-01-26 224930.jpg (46.18 KiB) Viewed 346 times
Here are some links for you to peruse.
http://forum.freecadweb.org/viewtopic.php?f=3&t=2264
https://wiki.freecadweb.org/Tutorials
Part_and_PartDesign
Part_and_PartDesign
Yes.
Oh, you want the answer as well??
Move all sketches to the same body. (Your design makes no sense, but that is a different issue.)
Then you can easily merge the sketches.
Gene
