Creating B-Splines from imported ASC file
Does FreeCAD have an option to convert points imported from ASC file into B-Splines automatically or we have to create them ourselves manually using B-Spline in draft WB?
Thanks - Hooshsim
Thanks - Hooshsim
Re: Creating B-Splines from imported ASC file
Maybe my own ignorance: what is an ASC file? Juwt ASCII text?
@hooshsim forgot to tag you for above question. I don't know if it works if I edit.
It's a very simple format of a point cloud where in each line you have three coordinates:
Example:
0.0000 0.0000 0.0000
0.1234 1.0345 2.6578
As far as I know there is no automatic method to create B-Splines from the point cloud.
The cloud is represented as one object in the model tree.
See the example below from the Dehler-Yacht.
How should the algorithm know which points to connect? Example taken from @hammax:
https://forum.freecadweb.org/viewtopic.php?f=13&t=74839
It is not very complicated to convert such a file in something that FreeCAD can utilize to be passed to a BSPline method, already done for NACA airfoil profiles sone time ago, and more recently to scan some molecular Data from an ASCII file.
Sorry I have no computer at hand for some time to supply dome code. But probably earching for "airfoil" and my nickname probably will give some results.
Regards
Carlo D.
Regards
Carlo D.
- Various other stuffs.
This is very easy. Import your ascii file splinedat.asc using the Points workbench. In the python console:
import Draft
doc = App.ActiveDocument
shp = doc.getObject("splinedat").Points
Draft.makeBSpline(shp.Points)
doc.recompute()
Surfaces can be made manually if points are not too many.
import Draft
selobj = Gui.Selection.getSelection()
obj = selobj[0]
count = len(obj.Points.Points)
i = 0
comp = App.activeDocument().addObject("Part::Compound","Points_Compound")
for pt in obj.Points.Points:
p = Draft.makePoint(pt)
comp.Links += [p]
i += 1
print ("Nb points = "+str(count))
- Capture.JPG (41.95 KiB) Viewed 690 times
- boat.FCStd
- (244.6 KiB) Downloaded 12 times
Vincent,
What’s this code and how to use it. I’m not an expert on freecad. Please advice
Thanks-Hooshsim
Thanks-Hooshsim
