Problems exporting
Problems exporting
Hi! First of all, this is my very first CAD experience so the piece is probably done in the worst and longest way possible, but it is what it is.
The problem comes when I export it, because one extra prism appears for no apparent reason.
I've tried to export pieces separately and they look fine but when I export the whole file is when this problem appears (you will see it much better in the pic). It looks like a duplicate object but I checked and I'm pretty sure there isn't any.
Maybe I'm doing something wrong when exporting it. I just Ctr+A to all the bodies and export them.
Hope I can get some help.
Thanks in advance
Thanks in advance
- rotarybottom.FCStd
- (399.43 KiB) Downloaded 16 times
- Captura.PNG (122.57 KiB) Viewed 834 times
Re: Problems exporting
All of this can be modeled in a single body by use of a polar pattern.
In any case, for the immediate problem, you need to select only the last element in each body, not all. The last element in a body contains all of the information. Adding every element means that some items are duplicated.
Gene
Thx for the reply. If I only select the last element on each body this is what happens
- Captura.PNG (48.41 KiB) Viewed 651 times
- Shalmeneser
"Je dirais même plus."
- rotarybottom_SHALM.FCStd
- (66.95 KiB) Downloaded 8 times
- Annotation 2023-01-27 113648.jpg (29.73 KiB) Viewed 648 times
This not wrong. But as long as the tip is set to the last feature, then selecting the Body only, represents the solid right?GeneFC wrote: ↑Fri Jan 27, 2023 2:39 amAll of this can be modeled in a single body by use of a polar pattern.
Gene
Okay yeah this is definitely the way to do it. I think I have not yet reached that youtube tutorial hahah.
But, how can you sketch an extrude another piece in a Pad without getting the "result has multiple solids" error?
Thank you all <3
I have not tried that. One would need to go to each Body separately and select it.
But CTRL-A followed by CTRL-C will definitely cause a problem.
That is not exactly what was done, but once the CTRL-A is used the game is over.
Gene
- Shalmeneser
All my features keep one solid. The PolarPattern can do multiple body if occurrence < 12, but FC will not keep them (so will not do anything).
I know they're only one solid, but I tried to replicate what you did to learn how to do it and when I add the triangle to the first pad and try to extrude it that error pops up. Idk if I have to do something to "join" the pad with the new sketch or smth.Shalmeneser wrote: ↑Fri Jan 27, 2023 1:37 pm??
- Shalmeneser
Always provide your file.
Each new feature in PartDesign wb must connect to the past solid.
