I can't find the "non-solid"
KDM
Post by KDM »
I'm trying to create a cut in the enclosed file, where I delete my object "Cuts" from "Solid". I'm told "The use of non-solids for boolean operations may lead to unexpected results."
I've had this before and it was because I forgot to click "Create Solid" when I was doing an extrusion. Here, I can't find which is the non-solid. I think it's probably in one of the arrays, but can't see it.
the cut seems to work, but I have a feeling it will go badly when I export an STL and try to load that into my slicer.
Can anyone help, please?
Thanks in advance!
EndPlugs 1in.FCStd
(99.68 KiB) Downloaded 25 times
Re: I can't find the "non-solid"
CheckGeometry says both are solids. May be an issue with the links.
KDM
Post by KDM »
I don't understand "links"? Can you help again, please?
drmacro
Post by drmacro »
Hmm...here it passes geometry check in FreeCAD. And the exported stl seems to pass the 3D print checks and manifold check in Blender.
KDM wrote: Sun Jan 29, 2023 3:13 pm I don't understand "links"? Can you help again, please?
For "Lugs" and "Slits" you used Draft arrays. they come in different flavors, where the Link version doesn't really copy the elements. If no other power user objects, you should create a ticket on Gthub.
drmacro wrote: Sun Jan 29, 2023 3:41 pm Hmm...here it passes geometry check in FreeCAD.
The result here is ok as well. Do you too get the intermediate message with the non solids when you create the cut?
Shalmeneser
Post by Shalmeneser »
:idea:
Just for PartDesign fans.
EndPlugs 1in_SHALM.FCStd
(144.58 KiB) Downloaded 15 times
Capture d’écran 2023-01-29 172300.jpg (59.25 KiB) Viewed 808 times
drmacro
Post by drmacro »
chrisb wrote: Sun Jan 29, 2023 4:01 pm
I didn't attempt any operations. I opened the file, no errors. I also did a recompute with no errors.
domad
Post by domad »
KDM wrote: Sun Jan 29, 2023 12:30 pm ....
Hi KDM, greetings to the Community!
It's not a bug but a surface intersection problem, you simply have to lower, on the "Z" axis, the cut sphere "Lug" by a few hundredths or thousandths of a mm, and everything will work.
Attached is your file which contains the lowering of "Lug" on the "Z" axis
EndPlugs 1in_domad.FCStd
(99.54 KiB) Downloaded 11 times
drmacro wrote: Sun Jan 29, 2023 4:39 pm I didn't attempt any operations. I opened the file, no errors. I also did a recompute with no errors.
Can you try to redo the top level cut?
