1. File new
2. Create Body
3. Create Sketch XY_Plane
4. Choose Circle and draw circle from axis center.
5. Constrain Circle Diameter to 10mm.
6. Close task.
7. Pad Part. Click OK.
This is where the issue exists, or functionality has changed. In the past, double clicking the pad in the Combo View that was just created would bring up the pad dialog in Tasks of the Combo View. Recently double clicking brings up the translate dialog. I can get to the Pad parameters by single clicking pad and then editing values in the Property/Value area. Or, I can get to the Pad dialog by right clicking Pad and select Edit Pad. Frequently if I need to edit the pad, it is because I forgot to place a value in a spreadsheet for a parametric pad. So I edit the spreadsheet and then go back to enter the spreadsheet parameter for the Pad Length.
It is not limited to Pad. If I do a revolution, the same thing happens. A double click on revolution in the Combo View takes me to Translate. If I right click, I can select Edit Revolution and get to where I want.
I much rather prefer double clicking take me to the appropriate dialog. I don't see a need to constantly translate everything.
My version info is:
OS: macOS 10.16
Version: 0.21.0.31709 (Git)
Hash: e188802ca6997d2564e7570ab648462e6a059f87
Python 3.10.8, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: C/Default (C)
Installed mods:
* ThreadProfile 1.83.0
* dodo
* sheetmetal.backup1663254342.459754
* sheetmetal.backup1663252767.516832
* sheetmetal.backup1663253572.586379
* sheetmetal.backup1663252689.521863
* A2plus 0.4.59
* fasteners 0.4.6
* sheetmetal 0.2.57
* sheetmetal.backup1663254477.573518
* sheetmetal.backup1663270894.490148
Bob
