Hi all, hope you're well
In FreeCAD if I have an oject with Appearance set with material colors etc.
How to copy and appply its appearance to other object(s)?
cheers,
Dorin
How to copy Appearance from an object to other(s)?
Re: How to copy Appearance from an object to other(s)?
Hi DorinDXN, Greetings to the Community!
... from "settig Style" you can create a style and apply it to another object
- setting_Style.png (88.37 KiB) Viewed 762 times
Thanks for quick reply, like I said it is about material colors.
If you select a cube in Part wrokbench then right-click and choose Appearence,
then Select Material as bronze, then click on [...] and adjust the colors...
There is no save properties as preset, nor copy.
How to apply that Appearance to other objects without going through every color?
cheers,
Dorin
cheers,
Dorin
With a bit of Python coding, it is possible to apply one object's color to others:
sel = Gui.Selection.getSelection()
sel_origin = sel[0]
color_origin = sel_origin.ViewObject.ShapeColor
if len(sel)<2:
App.Console.PrintMessage("select at least two objects")
else:
for i in sel:
if i.Name == sel_origin.Name:
pass
i.ViewObject.ShapeColor = color_origin
Use:
- Select two or more objects.
- Run the code. You can do it using a macro or just copy the code and paste it into the Python Console.
It would be possible to extend the code and add all the appearance properties that you want to be inherited.
Thank you for reply,
I noticed only after I had an work-around I was happy with
I made some buttons on a toolbar to a set speciffic material to all selected objects
e.g. this is for black shiny Al.
cheers,
Dorin
import FreeCAD as App, FreeCADGui as Gui
s=FreeCADGui.Selection.getSelection()
sc=len(s)
for p in range(sc):
if not(("Base" == App.ActiveDocument.getObject(s[p].Name).ViewObject.DisplayMode) or ("Group" == App.ActiveDocument.getObject(s[p].Name).ViewObject.DisplayMode)):
App.ActiveDocument.getObject(s[p].Name).ViewObject.DisplayMode="Shaded"
App.ActiveDocument.getObject(s[p].Name).touch()
if (hasattr(App.ActiveDocument.getObject(s[p].Name).ViewObject, 'ShapeMaterial')):
r=43
g=43
b=43
col=(r/255.0,g/255.0,b/255.0,1.0)
App.ActiveDocument.getObject(s[p].Name).ViewObject.ShapeMaterial.DiffuseColor=col
r=32
g=32
b=32
App.ActiveDocument.getObject(s[p].Name).ViewObject.ShapeMaterial.AmbientColor=col
r=0
g=0
b=0
App.ActiveDocument.getObject(s[p].Name).ViewObject.ShapeMaterial.EmissiveColor=col
r=150
g=150
b=150
App.ActiveDocument.getObject(s[p].Name).ViewObject.ShapeMaterial.SpecularColor=col
sn=0.99
App.ActiveDocument.getObject(s[p].Name).ViewObject.ShapeMaterial.Shininess=sn
cheers,
Dorin
