Q on addon manager [Solved]
ebolisa
Post by ebolisa »
Since I upgraded to 0.20.2 (from a prior version) I'm having problems with the addon manager. I cannot install new workbenches/micros nor I can upgrade them even though the addon mgr is telling me that new updates are available.
What am I doing wrong?
TIA
OS: Windows 10 Version 2009
Version: 0.20.2.29177 +426 (Git)
Branch: (HEAD detached from 0.20.2)
Hash: 930dd9a76203a3260b1e6256c70c1c3cad8c5cb8
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Locale: Spanish/Spain (es_ES)
Installed mods:
  * Curves 0.6.5
  * dodo 1.0.0
  * fasteners
  * fasteners.bak
  * ThreadProfile
chennes
Re: Q on addon manager
Post by chennes »
Can you open up Report View and see if there is any extra information there? If not, turn on the Log options in Preferences, run the Addon Manager again, and paste the output in a code block here.
Chris Hennes
Pioneer Library System
ebolisa
Post by ebolisa »
chennes wrote: Tue Jan 31, 2023 12:47 pm Can you open up Report View and see if there is any extra information there? If not, turn on the Log options in Preferences, run the Addon Manager again, and paste the output in a code block here.
So, it looks like my macro is causing the problem?
14:03:18  flag
14:03:18  flag2
14:03:46  Addon Manager: Unexpected 0 response from server
14:03:46  Unable to open macro code URL https://gist.github.com/mwganson/97d185ac2114701b26d3da47dccc9f7a/raw/e5ba077a671824a9908f4cb0ff178bf4502a2045/Honeycomb.FCMacro
chennes
Post by chennes »
That error shouldn’t prevent other updates: if it does, it is a bug. Is anyone else seeing this problem? Well, either problem: the broken macro raw_code link, or the failure to update when using Zip?
Chris Hennes
ebolisa
Post by ebolisa »
chennes wrote: Tue Jan 31, 2023 1:11 pm That error shouldn’t prevent other updates: if it does, it is a bug. Is anyone else seeing this problem? Well, either problem: the broken macro raw_code link, or the failure to update when using Zip?
My browser won't allow to get to the git site due to a security issue ("Did Not Connect: Potential Security Issue"). Which may be the problem.https://codeload.github.com/mwganson/Th ... ads/master
ebolisa
Re: Q on addon manager [Solved]
Post by ebolisa »
The problem was caused by my ISP which was blocking the pages. Solved by using a connection through my cellular's personal hotspot.
