TechDraw: Strange rounding error
dobrowolsk
Post by dobrowolsk »
These two holes have the same y value, as defined by a sketch. A few minutes ago, this worked. Then I changed some things in the sketches that make up this part. This also happens for other parts that have the same x or y values. Sometimes closing and re-opening the file helps, but in some cases, it doesn't.
I have tried, without success :
  • to constrain the hole in another way,
  • to fiddle around with the format spec of this dimension
  • to fiddle around with the global format settings and with the dimension number format settings in the TechDraw settings dialog
A few minutes later this happened. These holes are constrained to have the same x value, per the sketch that creates them:
These are the properties of this dimension:
According to all the settings, it should never happen that something like "0.000000000000012" ever comes into existence.
This is the file in question: http://www.dobrowolsk.de/dobro/Bohrungs ... port.FCStd
Any idea? Thanks!
OS: Windows 10 Version 2009
Version: 0.20.2.29177 +426 (Git)
Branch: (HEAD detached from 0.20.2)
Hash: 930dd9a76203a3260b1e6256c70c1c3cad8c5cb8
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Installed mods:
  * 3D_Printing_Tools
  * A2plus 0.4.60h
  * Assembly4 0.12.5
  * BOLTSFC
  * Curves 0.6.5
  * fasteners 0.4.54
  * kicadStepUpMod 10.17.1
  * Manipulator 1.4.9
Shalmeneser
Re: TechDraw: Strange rounding error
Post by Shalmeneser »
I don't have answer to your question,
* you should TechDraw when your object is very stable
* you should not repeat same dimensions twice in a sketch. Use geometrical constraints instead.
* You should never use zero dimensions. Use geometrical constraints instead.
* You should do multiple but simple sketches : KISS method : keep it stupidly simple
* you should not give dimensions for all holes in TechDraw (too much data) but provide a X/Y/R TechDraw_SpreadsheetView instead. Use this SpreadSheet for your sketches also.
dobrowolsk wrote: Tue Jan 31, 2023 12:55 pm Any idea? Thanks!
I don't see the issue here. Try the following:
- Mark the whole model for recompute and recompute
- Reload the file
- Restart FreeCAD
