How to create a coordinate system or frame of axis?
westerj
Re: How to create a coordinate system or frame of axis?
Post by westerj »
It seems very possible to do this by the creation of a 3D face, and then sketching on that. That is essentially the same as constructing a local coordinate system. Can it be automated with 3 points? First point in 3d Space is the origin. Second point defines the X Axis. THen the third point is used to nail the vector to the Y Axis. that third point wouldn't have to be -on- the Y axis, but it could fully constrain the new X' Y' coordinate system. then you can sketch on.
mario52
Post by mario52 »
hi welcome westerj
yes it's easy just to code
and must also follow the axis of coordinates tilt yaw pitch roll and all the built forms follow these positions
mario
westerj
Post by westerj »
Ok... so i am getting that a freecad file is a hybrid of (boolean, surfaces, cuts etc) + code. A coordinate system be a useful primitive though.
Where to RTFM?
Create Sketch ->
-> Select plane:
XY
YZ
XZ
User specified (6 Degrees of freedom)
Select Face
Ok. So I am lazy. Avoiding construction of face to sketch on...
Say I am modeling a keylock/cylinder in FreeCAD. Would i have one FreeCAD file or would i create each as separate Part and then go into the assembly workbench?
THanks! JW (FreeCAD newbie, CADDS4x/CADDS5/ProeV9-18 a few years back)
NormandC
Post by NormandC »
westerj wrote:Say I am modeling a keylock/cylinder in FreeCAD. Would i have one FreeCAD file or would i create each as separate Part and then go into the assembly workbench?
For now it's only a matter of preference. Some prefer to work with separate files, then export them as STEP and import those STEP parts into a new file to make an assembly.
There is no functional assembly workbench at the moment. There may be an Assembly entry in the workbench switcher, but it doesn't work.
At some point in the future, arbitrary plane creation will be possible, the assembly workbench will be functional, but we are not there yet.
Where to RTFM?
Help menu --> Users documentation
But I prefer the wiki's Main Page as a starting point.
microelly2
Post by microelly2 »
Maybe this can be useful
to create helper structures
viewtopic.php?f=8&t=6452&p=52070#p52010
jmaustpc
Post by jmaustpc »
normandc wrote:At some point in the future, arbitrary plane creation will be possible, the assembly workbench will be functional, but we are not there yet.
As Norm said, they are coming one day, they are already there in the Assembly working branch version of FreeCAD...here is an edited screen shot...
Jim
OS: Ubuntu 14.04.1 LTS
Version: 0.15.4565 (Git)
Branch: assembly_jmaustpc_working
Hash: d76cd15deb64414354ccfd11faec588c80debf15
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.7.1
westerj
Post by westerj »
Thanks All. I see there is much vitality with FreeCAD, which is fantastic! What happens when an IGES file with record type 124 is imported? This seems to be the coordinate system / transformation matrix. Is this supported? http://www.3dmodelzone.com/iges-section-p.html. It can take some time to understand how to relate things together in any system. Thanks again! JW
el hombre
Post by el hombre »
Coordinate systems are nothing new in mathematics. Without them it is hard to imagine operations in different spaces. There is an old parametric cad Varkon ( http://varkon.sourceforge.net/ ), a well developed concept. It has not been developed since 2005 but it has lots of good working ideas. Someone with good imagination could “type” geometry” without using graphical interface. Mathematical part of this cad is based on this book Faux I.D., Pratt M.J. Computational Geometry for Design and Manufacture
http://www.twirpx.com/file/1199095/
