export in IGES Brep
talziary
export in IGES Brep
Postby talziary » Mon Oct 20, 2014 10:27 am
Is it possible to export a solid in IGES Brep format i.e with a description starting with a MSBO entity (186) instead of the present default which is a set of trimmed parametric surface entities (144) ?
According to the OOCT documentation this should be possible by setting write.iges.brep.mode to 1 but I dont know if this is possible within FreeCAD.
OS: Linux Fedora fc20
Word size: 64-bit
Version: 0.14.$WCREV$
Python version: 2.7.5
Qt version: 4.8.6
Coin version: 2.5.0
SoQt version: 1.5.0
OCC version: 6.7.1
Site Admin
Re: export in IGES Brep
Postby wmayer » Mon Oct 20, 2014 11:04 am
Try
Part.setStaticValue("write.iges.brep.mode", 1)
and then do the export again.
quick61
Postby quick61 » Mon Oct 20, 2014 8:50 pm
wmayer wrote:Try
Hi wmayer,
This works great! As a test, I exported a shape, Cube cut with Cylinder, both ways. -(see attached files)- The results when opening both exports were the default export's geometry check, (001testIGES.iges), produced BOPAlgo SelfIntersect errors on every edge and vertex with a Shape Content of -
Unnamed1._01testIGES:
 VERTEX    : 28
 EDGE      : 30
 WIRE      : 9
 FACE      : 7
 SHELL     : 0
 SOLID     : 0
 COMPSOLID : 0
 COMPOUND  : 1
 SHAPE     : 75
- and with the " Part.setStaticValue("write.iges.brep.mode", 1) " applied to the part before exporting, (001testIGES_186.iges), results in no geometry errors and the following Shape Content -
Unnamed2._01testIGES_186:
 VERTEX    : 10
 EDGE      : 15
 WIRE      : 9
 FACE      : 7
 SHELL     : 1
 SOLID     : 1
 COMPSOLID : 0
 COMPOUND  : 0
 SHAPE     : 43
001testIGES.iges
(17.8 KiB) Downloaded 59 times
(17.24 KiB) Downloaded 54 times
Question, should this be an option built into the export function of FreeCAD? Like "Export > IGES" and "Export > IGES Solid".
Mark
OS: Kubuntu 14.04.1 LTS
Word size: 64-bit
Version: 0.14.3705 (Git)
Branch: releases/FreeCAD-0-14
Hash: f25e6e4716fb63ef3ac618ce9e552761bbc1b4b1
Python version: 2.7.6
Qt version: 4.8.6
SoQt version: 1.6.0a
OCC version: 6.7.1
NormandC
Postby NormandC » Mon Oct 20, 2014 10:05 pm
Isn't there a bug on Mantis about invalid IGES import from some CAM software? This might solve it.
quick61
Postby quick61 » Mon Oct 20, 2014 10:09 pm
normandc wrote:Isn't there a bug on Mantis about invalid IGES import from some CAM software? This might solve it.
Yes, I was just on Mantis looking for that. :) But my default view has changed for some reason. :? Anyway, I'm back looking for it now.
Mark
quick61
Postby quick61 » Mon Oct 20, 2014 10:18 pm
Found it - issue #1769
Added a note referencing wmayer's post above.
Mark
Site Admin
Postby wmayer » Tue Oct 21, 2014 9:18 am
Mark, you replied to the bug reporter:
Exporting the Cube in IGES format, then opening that IGES file in FreeCAD produces SelfInteresct errors with every edge and vertex of the cube, and object is not a solid or shell, just a compound of self intersecting edges and vertexes of faces.
This is with both FreeCAD 0.14 Release (3705) and -
So, if I got you right then you at least have self-intersection problems when reloading the exported box as IGES file. Do you also have the "exploded" box? Does it work with STEP? Does "Part.setStaticValue("write.iges.brep.mode", 1)" change anything?
I tried "Part.setStaticValue("write.iges.brep.mode",1)" and "Part.setStaticValue("write.iges.brep.mode",0)" and observed that the files are quite different but I didn't observe any problems.
talziary
Postby talziary » Tue Oct 21, 2014 12:55 pm
Hi wmayer,
Many thanks for your help. Works well : tested on a complex shell involving 185 faces.
quick61
Postby quick61 » Tue Oct 21, 2014 2:54 pm
wmayer wrote:Mark, you replied to the bug reporter:
Yes, the errors occur with both release 0.14 - 3705, and development 0.15 - 4131. Both were built with OCE 0.17 dev (OCE 0.16 with a name change). My OCE is a complete build with all options & TBB.
I'm not sure what you mean by "exploded" box, but everything works well with STEP export, STEP and STEP with color export a solid. It's just the default IGES export that is nothing but a group of faces with self intersecting edges and vertexes. I should note that I do have BOPCheck enabled. With BOPCheck disabled, I do not get the errors but the Check geometry > Shape Content is the same, no shell, no solid. I think that is the difference your seeing in the two files, one is just a compound of faces, (the smaller one), the other is a solid.
Mark
Site Admin
Postby wmayer » Tue Oct 21, 2014 4:03 pm
Thanks. Now after activating "RunBOPCheck" I see the errors too in the geometry check. And from scripting I can see that the box has 24 edges (instead of 12) and 24 vertexes (instead of 8).
This is answered now. What I meant is the same behaviour as http://www.freecadweb.org/tracker/file_ ... 6&type=bug
