keyboard shortcuts
Archimage
keyboard shortcuts
Post by Archimage »
I've installed Freecad 4075 from the AUR in Arch.
I can't manage to use keyboard shortcuts, for example, when I press "L" to draw a line, nothing happens. Am I missing something ?
Thank you !
Founder
Re: keyboard shortcuts
Post by wmayer »
Did you create a document and inserted a sketch object into there? And the sketch object must also be in editing mode. To do so just double-click on it. You'll see that the according tree item is yellow highlighted.
That the shortcut is not working is an indication that the command is inactive and with the above conditions you make it active.
Archimage
Post by Archimage »
Thank you !
Shortcuts are working in the sketch mode.
Why can't we use the shortcuts for 2d drafting outside the sketch mode ? I ask for this because the line command is active but we have to click the icon each time we draw a line
Regards
Founder
Post by wmayer »
As far as I can see for none of the commands in the Draft menu a shortcut is defined. But you should be able to customize the commands you often use to set a shortcut for them. Go to Tools > Customize > Keyboard. Then select the category Python (because the whole Draft module is written in Python), select the command, defined a shortcut and click on Assign.
yorik
Founder
Post by yorik »
Maybe I should define a set of "default" shortcuts in the draft module? Werner, is there a way to do that?
Founder
Post by wmayer »
Yes, this can be added easily. We just need to expand the resource map of a python command. Then in C++ I have to write a few lines of code to support that.
Founder
Post by wmayer »
OK, done with rev. 4140.
The GetResource method now should something like:
	def GetResources(self):
		return {'Pixmap'  : 'Draft_Arc',
			'Accel' : "CTRL+H",
			'MenuText': QtCore.QT_TRANSLATE_NOOP("Draft_Arc", "Arc"),
			'ToolTip': QtCore.QT_TRANSLATE_NOOP("Draft_Arc", "Creates an arc. CTRL to snap, SHIFT to constrain")}
yorik
Founder
Post by yorik »
Perfect! I'll adapt the command resources.
zbigg
Post by zbigg »
As of v.0.17 build 13452:
Is shortcuts feature to be fully functional in 0.17 release?
As one may notice its hardly functional so far and it'd be VERY useful for smooth workflow...
cheers,
yorik
Founder
Post by yorik »
zbigg wrote: Wed Mar 28, 2018 12:19 pm Is shortcuts feature to be fully functional in 0.17 release?
It's functional since 2011 :) What did you find that doesn't work?
