Center of a Rectangle
demackison
Postby demackison » Tue Dec 02, 2014 4:42 pm
Is there a way to constrain the center of a rectangle (or other symmetrical non-arc/circle)?
jmaustpc
Re: Center of a Rectangle
Postby jmaustpc » Tue Dec 02, 2014 4:46 pm
demackison wrote:Is there a way to constrain the center of a rectangle (or other symmetrical non-arc/circle)?
Are you asking about PartDesign/sketcher?
If so, use symmetry constraint with two diagonally opposed vertices.
demackison
Postby demackison » Tue Dec 02, 2014 5:11 pm
jmaustpc wrote: Are you asking about PartDesign/sketcher?
Yes.
jmaustpc wrote:If so, use symmetry constraint with two diagonally opposed vertices.
I looked at http://www.freecadweb.org/wiki/index.ph ... _Symmetric and I don't see how to let the program know which of the three points is the center.
NormandC
Postby NormandC » Tue Dec 02, 2014 5:40 pm
The third selected point will be considered the center.
From the command page you linked:
The documentation wrote:Alternatively it can constrain two points to be symmetric with respect to a third one.
jmaustpc
Postby jmaustpc » Wed Dec 03, 2014 12:38 am
if you put the mouse pointer over the toll it pops up a tool tip that tells you how to use the tool, as with the other tools. Are your tool tips not working?
NormandC
Postby NormandC » Wed Dec 03, 2014 1:40 am
I just remembered I recorded a quick video a year ago. Starting at 1:40 I'm adding a symmetric constraint between diagonally opposed filleted corners of a rectangle and the origin point.
http://youtu.be/w2HGxWmMr-A
cox
Postby cox » Wed Dec 03, 2014 9:11 pm
While reading this post i tried some constraints on rectangles and I found some strange behavior.
In the attached file, select first the two most left vertices, then the lower line of the right most rectangle(or one of its vertices). After selecting symmetry constraint on these selections all geometry bunches up in a vertical line.
Could this be a bug?
OS: "Arch Linux"
Version: 0.15.4199 (Git)
Hash: 3904d0a8ee63b67979e9e71e61e423cfe331926a
Python version: 2.7.8
Qt version: 4.8.6
Coin version: 3.1.3
OCC version: 6.7.1
centerconstr.fcstd
(3.12 KiB) Downloaded 51 times
NormandC
Postby NormandC » Wed Dec 03, 2014 10:00 pm
I can't reproduce on the current latest release on Windows. The symmetric constraint gets added as expected.
OS: Windows 7
Word size: 64-bit
Version: 0.14.3700 (Git)
Branch: releases/FreeCAD-0-14
Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1
Python version: 2.7.6
Qt version: 4.8.5
SoQt version: 1.6.0a
OCC version: 6.6.0
I will test on the Daily Build tonight.
bejant
Postby bejant » Wed Dec 03, 2014 10:27 pm
Works as expected for me using:
OS: Ubuntu 14.04.1 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.15.4236 (Git)
Hash: f5a4e680681f30bb9396f1968ec3f9f82d175837
Qt version: 4.8.6
OCC version: 6.7.1
cox
Postby cox » Wed Dec 03, 2014 10:41 pm
Could you please post a file with the final constraint applied so i can test.
