Exploded assembly animation
Hi!
To take a rest of the sheet metal stuff I've coded this little workbench, preview video here:
https://www.youtube.com/watch?v=1KZB50rTWpE
I'm currently finishing the code, I'll upload it together with a new tutorial video once I get everything to work.
Then, you should be able to explode several objects at the same time, rotate along trajectory and more.
What do you think?
Javier.
What do you think?
Javier.
FreeCAD scripts, animations, experiments and more: http://linuxforanengineer.blogspot.com.es/
Open source CNC hot wire cutter project (NiCr): https://github.com/JMG1/NiCr
Exploded Assembly Workbench: https://github.com/JMG1/ExplodedAssembly
Re: Exploded assembly animation
As promised, the video:
https://www.youtube.com/watch?v=1hrz7jt_JZw
I'll try to create a repository in github, so you can see the files without downloading -> Done!:
https://github.com/JMG1/FreeCAD_Explode ... nWorkbench
- microelly2
thank you, good job
will you animate the unfold process too? I think this is the next powerful feature.
Thanks, microelly!
I would be very happy even if I manage to draw the unfolded projection onlywill you animate the unfold process too?
You're right. I've code this small feature to teach myself about workbench creation. The next target is the sheet metal workbench, but if something interesting comes along the way, it can have a place too.I think this is the next powerful feature.
- microelly2
I have inspected your first code to create a folded object. This program can already become animatable.JMG wrote: I would be very happy even if I manage to draw the unfolded projection only
Hey! This is great. I noticed one small bug, however. Here is the fix:
You set the routeName to the name of the NewRoute, because addObject renames objects that are given names with spaces in them.
*** ExplodedAssemblyAnimation/EACommands.py 2015-01-08 00:34:16.538308999 +0000
--- .FreeCAD/Mod/ExplodedAssemblyAnimation/EACommands.py 2015-01-08 00:33:51.634308999 +0000
*** 117,121 ****
# ADD ROUTE SKETCH
SelObjName = "Rt_" + Gui.Selection.getSelection()[0].Label
- TD.RouteName = SelObjName
SelFace = Gui.Selection.getSelectionEx()[0].SubObjects[0]
faceCom = SelFace.CenterOfMass
--- 117,120 ----
*** 123,126 ****
--- 122,126 ----
V_0 = ( P_A - faceCom ).normalize()
NewRoute = AAD.addObject("Sketcher::SketchObject", SelObjName)
+ TD.RouteName = NewRoute.Name
RouteFolder = AAD.getObject( "EA_Routes" )
RouteFolder.addObject( NewRoute )
Hallo Guys,
i would like to made some exploded assambly animations. I have download the zip file and bring it zo the free cad folder.
I have effort it but it dos not work with my parts, there are some fault messages.
Please help i need it for my company.
Regards Gerhard
sorry, my english is not well enough
Regards Gerhard
Hello PS-europe.
With the little info that you provide is impossible to tell what could be wrong.
Please, post the error messages here or even better, attach the fcstd file where they happen.
Javier.
Javier.
Hello Javier,
I will do it at the evening.
cheers and thank you for the responce
This is an infrared heating element with mounting plate on the concrete sealing. I would like to show my clients the steps of the product fixing on the sealing and the layers of the element. If I choose a part and it works just, I can set the path only in the horizontal axis. perpendicular to the surface is never. Or will it showed me images this following error:
Wrong selection
please help, what I am doing wrong?
Wrong selection
- Explusionszeichnung V10 test explusion.FCStd
- (380.18 KiB) Downloaded 365 times
