Exploded assembly animation
YCStone_
Re: Exploded assembly animation
Postby YCStone_ » Wed Nov 16, 2016 1:44 am
therman wrote:Thanks, in the meantime I figured that out However I'm not sure why it is counted from the end, rather than from the beginning. Anyways, I wrote a function that asks for the start index, end index and the number of animations, and calls your function with the correct parameters.
And to show my appreciation to you, I'd like to show you the video I was able to create with your workbench:
https://youtu.be/zMzEMR8Gdp8
I'm part of the team that develops the possible second Hungarian satellite, SMOG-1 and I created this demo video to show the build up of the device.
The animation was purely run by python script, including the Exploded Assembly functions.
Thanks!
Hi Therman
can you share to us your animation code
much appreciated - thanks!
YC Stone Natural Stone Supplier
ikua
Postby ikua » Tue Mar 27, 2018 10:34 am
Awesome Workbench!
But i could not find a way to export a video file from the animation. Is there a known way?
Edit:
Found a good solution. Downloaded OBS screen record tool. Unlocked drawing window and put it on my second monitor. Started the recording and afterwards started and ended recording from my first monitor.
dajomu
Re: Automatic Exploded assembly
Postby dajomu » Sun Jan 19, 2020 10:21 pm
I have posted another thread regarding automatic exploded view and I was told thatFreecad has Workbench.
I guess you already know about the Paper I refer to, nbit still I would like to mention it still. What do uou think about this and is it possible to implement in Workbench?
See link to thread below.
https://forum.freecadweb.org/viewtopic.php?f=8&t=42403
funkysod
Postby funkysod » Fri Jan 24, 2020 5:12 pm
This workbench is just awesome.. thanks!
EDIT: Made a small demo of one of my models. https://youtu.be/tG0rRqtcxbg
m8_608_pulley_exploded_assembly.fcstd
(124.96 KiB) Downloaded 20 times
Postby chrisb » Fri Jan 24, 2020 6:55 pm
Is there any written documentation beyond the examples?
tolap
Postby tolap » Tue Apr 14, 2020 6:42 am
the AlignToEdge function does not work:
Running the Python command 'AlignToEdge' failed:
File "C: \ Users \ Administrator \ AppData \ Roaming \ FreeCAD \ Mod \ ExplodedAssembly \ EAInit.py", line 386, in Activated
va = (edgeA.Curve.EndPoint - edgeA.Curve.StartPoint) .normalize ()
'Part.Line' object has no attribute 'EndPoint'
Can you help me fix the code?
FreeCAD info:
OS: Windows 7
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: French/France (fr_FR)
alexu
Postby alexu » Wed Apr 15, 2020 1:10 pm
I suspect the objects you picked were not the type of objects the developer was expecting. As you found out, the code does not trap exceptions and provide useful messages as to what went wrong.
Exploded Assembly (EA) was written back when FreeCAD had limited or no Assembly tools, so it included a few basic tools of its own. Today I would suggest using one of the assembly workbenches to create your assembly and forego the EA tools. Once you have your assembly, you can use EA to tear it apart in an animated way.
Also note that you should create your explosion on a copy of your assembly. EA creates its own internal list of the starting locations of the objects it moves. if you apply EA to your main assembly file and then subsequently make changes to the assembly that relocates the base position of some objects, EA will be unaware and the animation will probably break.
Markymark
Postby Markymark » Thu Apr 16, 2020 7:42 am
Here: Modify Individual Object Trajectory
I was not able to figure out how this works ... or if this is just broken. I tired several (every) possible way to select object, edge, trajectory ... Find enclosed a very simple example. Trying to modify the trajectory I get the following message:
Running the Python command 'ModifyIndividualObjectTrajectory' failed:
  File "C:\Users\ADMIN\AppData\Roaming\FreeCAD\Mod\ExplodedAssembly\EAInit.py", line 140, in Activated
    ea.modifyIndividualObjectTrajectory()
  File "C:\Users\ADMIN\AppData\Roaming\FreeCAD\Mod\ExplodedAssembly\ExplodedAssembly.py", line 588, in modifyIndividualObjectTrajectory
    for i in range(len(sel_traj.names)):
'Part.Feature' object has no attribute 'names'
Any hints?
Thanks in advance! Mark
_________________________________________________
OS: Windows 8.1 (6.3)
Version: 0.19.20311 (Git)
Hash: 915e551bbb7e3614bc804f1ae1f65027b5432b9f
Python version: 3.6.8
Qt version: 5.12.1
Exploded_Assembly_Several_Directions.FCStd
(11.64 KiB) Downloaded 9 times
Postby chrisb » Thu Apr 16, 2020 8:10 am
I tend to split this topic or move it completely to Help forum. What do you think?
kisolre
Postby kisolre » Thu Apr 16, 2020 8:51 am
+1
