Problem z Path na fedora 35
Cześć. Gdy kliknę Job w module path wyskakuje mi masa alarmów i nic nie można zrobić. próbowałem przeinstalować program i nic to nie dało. Zainstalowane normalnie ze sklepu. Da się to jakoś prosto naprawić? Wyskakuj takie komunikaty :
23:03:13 Traceback (most recent call last):
File "/usr/lib64/freecad/Mod/Path/PathScripts/PathJobGui.py", line 139, in attach
self.axs = coin.SoType.fromName('SoAxisCrossKit').createInstance()
File "/usr/lib64/python3.10/site-packages/pivy/coin.py", line 491, in createInstance
return _coin.SoType_createInstance(self)
<class 'SystemError'>: <built-in function SoType_createInstance> returned a result with an exception set
23:03:14 PathJobGui.ERROR: <built-in function SoFieldContainer_getField> returned a result with an exception set
23:03:14 SystemError: PY_SSIZE_T_CLEAN macro must be defined for '#' formats
23:03:14
The above exception was the direct cause of the following exception:
23:03:14 Traceback (most recent call last):
23:03:14 File "/usr/lib64/freecad/Mod/Path/PathScripts/PathJobGui.py", line 1367, in Create
obj.ViewObject.Proxy.editObject(obj.Stock)
23:03:14 File "/usr/lib64/freecad/Mod/Path/PathScripts/PathJobGui.py", line 202, in editObject
return self.openTaskPanel('Stock')
23:03:14 File "/usr/lib64/freecad/Mod/Path/PathScripts/PathJobGui.py", line 186, in openTaskPanel
self.showOriginAxis(True)
23:03:14 File "/usr/lib64/freecad/Mod/Path/PathScripts/PathJobGui.py", line 162, in showOriginAxis
self.switch.whichChild = sw
23:03:14 File "/usr/lib64/python3.10/site-packages/pivy/coin.py", line 3998, in __setattr__
field = self.getField(name)
23:03:14 File "/usr/lib64/python3.10/site-packages/pivy/coin.py", line 3873, in getField
return _coin.SoFieldContainer_getField(self, name)
23:03:14 SystemError: <built-in function SoFieldContainer_getField> returned a result with an exception set
23:03:14
Mój system:
OS: Fedora Linux 35 (Workstation Edition) (GNOME/gnome)
Version: 0.19.Unknown
Build type: Unknown
Python version: 3.10.0rc1
Qt version: 5.15.2
Coin version: 4.0.0
OCC version: 7.5.0
Locale: Polish/Poland (pl_PL)
23:03:14
23:03:14
Mój system:
Build type: Unknown
Qt version: 5.15.2
Coin version: 4.0.0
OCC version: 7.5.0
Re: Problem z Path na fedora 35
Spróbuj odpalić pobrany jako Appimage https://wiki.freecadweb.org/AppImage
Wtedy FreeCAD będzie miał swoją wersję Pythona, z 3.10 są chyba problemy.
Jak robię zgodnie z instrukcją o ile ją dobrze rozumiem to wyskakuje mi takie coś. Poddaję się. Na stacjonarnym mam windowsa i tam mi wszystko działa. Jeszcze rozważam zmianę Fedory na innego linuxa. Wie ktoś na jakiej dystrybucji dziła FreeCAD bez problemów?
To po prostu pobrana paczka https://github.com/FreeCAD/FreeCAD-Bund ... 4.AppImage nie działa? W jakim celu próbujesz robić aktualizację? Z aktualizacjami Appimage są czasem problemy i lepiej po prostu ściągnąć nowszą wersję w całości.
- Shalmeneser
Udało mi sie zrobić. Zainstalowałem flatpaka https://flatpak.org/setup/Fedora/ a potem zainstalowałem z flathube https://flathub.org/apps/details/org.freecadweb.FreeCAD
Hej.
Zarówno kwahoo jak i Shalmeneser podali Ci linki do pobrania działającej aplikacji pozbawionej wady instalowania i problemu nie rozwiązanych zależności.
Gdy pobierzesz plik appimage, może okazać się konieczne nadanie mu uprawnień "do wykonywania",
potem klikasz w ikonkę jak w Windows. Zaleta - nowa aktualna wersja (nazywana deweloperską lub testową), wierz mi że jak obczaisz o co w niej chodzi nie będziesz chciał używać innej (stabilnej 0.19).
Pozdrawiam.
Pozdrawiam.
Twórca polskiej wersji Wiki dla FreeCAD, współwórca polskiej wersji GUI.
"Cierpliwym być musisz, by wiedzę zgłębiać tajemną, gdyż ciemna strona mocy niszczącą i silną jest".
Tel plik nie chciał się uruchomić. Zaznaczyłem, że ma być wykonywalny a mimo to sie nie uruchamiał. Włączało się to małe okienko niby się program ładował a potem się wyłączał. Pobrałem wersję stabilną zalecana oraz nowsze z githuba i wszystkie tak samo/
huh,
drobny przykład:
oczywiście plik musi być "twój" lub musisz posiadać odpowiednie uprawnienia, aby ta operacja się powiodła.
u mnie dało taki rezultat:
Szczególnie pierwszy raz uruchomienie trwa dłużej, ten plik z programem jest trochę specyficzny, i przy pierwszym uruchomieniu powiedzmy. że co nieco "musi się wypakować".
Z twojego opisu "uruchomienie" zdaje się przebiegać prawidłowo, przynajmniej na wstępie.
Spróbuj odpalić toto z konsoli, wtedy dodatkowe komunikaty, które mogą się pojawić, mogą zdradzić tajemnicę co jest na rzeczy.
po wyświetleniu ostatniego wiersza z komunikatem, musiałem jeszcze poczekać "kilka chwil" za nim wyświetlił się interfejs FC.
Owa ostatnia linia u Ciebie nie wystąpi.
trzymam kciuki
drobny przykład:
chmod +x FreeCAD_weekly-builds-26306-Linux-Conda_glibc2.12-x86_64.AppImage
ls -l FreeCAD_weekly-builds-26306-Linux-Conda_glibc2.12-x86_64.AppImage
-rwxr-xr-x 1 kaktus kaktus 960640192 11-11 07:19 FreeCAD_weekly-builds-26306-Linux-Conda_glibc2.12-x86_64.AppImage
podejrzewam że brakło Ci cierpliwości ...
$ ./FreeCAD_weekly-builds-26479-Linux-Conda_glibc2.12-x86_64.AppImage
FreeCAD 0.20, Libs: 0.20R26479 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2021
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
Sheet Metal workbench loaded
trzymam kciuki
Dodatkowo FC potrafi zapisywać logi https://wiki.freecadweb.org/Debugging/pl
Dla testu wrzuciłem Fedorę 35 na maszynę wirtualną i wygląda, że FC z Appimage działa, czyli problem musi być charakterystyczny dla konkretnej konfiguracji.
