Problem z Path na fedora 35
Polish forum
Moderators: PrzemoF, kaktus
Regulamin forum i pomocne informacje
WAŻNE! Przeczytaj zanim poprosisz o pomoc
Karas1920
Post by Karas1920 »
Cześć. Gdy kliknę Job w module path wyskakuje mi masa alarmów i nic nie można zrobić. próbowałem przeinstalować program i nic to nie dało. Zainstalowane normalnie ze sklepu. Da się to jakoś prosto naprawić? Wyskakuj takie komunikaty :
23:03:13 Traceback (most recent call last):
File "/usr/lib64/freecad/Mod/Path/PathScripts/PathJobGui.py", line 139, in attach
self.axs = coin.SoType.fromName('SoAxisCrossKit').createInstance()
File "/usr/lib64/python3.10/site-packages/pivy/coin.py", line 491, in createInstance
return _coin.SoType_createInstance(self)
<class 'SystemError'>: <built-in function SoType_createInstance> returned a result with an exception set
23:03:14 PathJobGui.ERROR: <built-in function SoFieldContainer_getField> returned a result with an exception set
23:03:14 SystemError: PY_SSIZE_T_CLEAN macro must be defined for '#' formats
23:03:14
The above exception was the direct cause of the following exception:
23:03:14 Traceback (most recent call last):
23:03:14 File "/usr/lib64/freecad/Mod/Path/PathScripts/PathJobGui.py", line 1367, in Create
obj.ViewObject.Proxy.editObject(obj.Stock)
23:03:14 File "/usr/lib64/freecad/Mod/Path/PathScripts/PathJobGui.py", line 202, in editObject
return self.openTaskPanel('Stock')
23:03:14 File "/usr/lib64/freecad/Mod/Path/PathScripts/PathJobGui.py", line 186, in openTaskPanel
self.showOriginAxis(True)
23:03:14 File "/usr/lib64/freecad/Mod/Path/PathScripts/PathJobGui.py", line 162, in showOriginAxis
self.switch.whichChild = sw
23:03:14 File "/usr/lib64/python3.10/site-packages/pivy/coin.py", line 3998, in __setattr__
field = self.getField(name)
23:03:14 File "/usr/lib64/python3.10/site-packages/pivy/coin.py", line 3873, in getField
return _coin.SoFieldContainer_getField(self, name)
23:03:14 SystemError: <built-in function SoFieldContainer_getField> returned a result with an exception set
23:03:14
Mój system:
OS: Fedora Linux 35 (Workstation Edition) (GNOME/gnome)
Version: 0.19.Unknown
Build type: Unknown
Python version: 3.10.0rc1
Qt version: 5.15.2
OCC version: 7.5.0
Locale: Polish/Poland (pl_PL)
Karas1920
Re: Problem z Path na fedora 35
Post by Karas1920 »
Jak robię zgodnie z instrukcją o ile ją dobrze rozumiem to wyskakuje mi takie coś. Poddaję się. Na stacjonarnym mam windowsa i tam mi wszystko działa. Jeszcze rozważam zmianę Fedory na innego linuxa. Wie ktoś na jakiej dystrybucji dziła FreeCAD bez problemów?
Zrzut ekranu z 2021-12-02 00-03-09.png (173.84 KiB) Viewed 5114 times
kwahoo
Post by kwahoo »
To po prostu pobrana paczka https://github.com/FreeCAD/FreeCAD-Bund ... 4.AppImage nie działa? W jakim celu próbujesz robić aktualizację? Z aktualizacjami Appimage są czasem problemy i lepiej po prostu ściągnąć nowszą wersję w całości.
Karas1920
Post by Karas1920 »
Udało mi sie zrobić. Zainstalowałem flatpaka https://flatpak.org/setup/Fedora/ a potem zainstalowałem z flathube https://flathub.org/apps/details/org.freecadweb.FreeCAD
kaktus
Post by kaktus »
Hej. :mrgreen:
Zarówno kwahoo jak i Shalmeneser podali Ci linki do pobrania działającej aplikacji pozbawionej wady instalowania i problemu nie rozwiązanych zależności.
Gdy pobierzesz plik appimage, może okazać się konieczne nadanie mu uprawnień "do wykonywania",
potem klikasz w ikonkę jak w Windows. Zaleta - nowa aktualna wersja (nazywana deweloperską lub testową), wierz mi że jak obczaisz o co w niej chodzi nie będziesz chciał używać innej (stabilnej 0.19).
Pozdrawiam.
Karas1920
Post by Karas1920 »
Tel plik nie chciał się uruchomić. Zaznaczyłem, że ma być wykonywalny a mimo to sie nie uruchamiał. Włączało się to małe okienko niby się program ładował a potem się wyłączał. Pobrałem wersję stabilną zalecana oraz nowsze z githuba i wszystkie tak samo/
kaktus
Post by kaktus »
huh,
drobny przykład:
chmod +x FreeCAD_weekly-builds-26306-Linux-Conda_glibc2.12-x86_64.AppImage
oczywiście plik musi być "twój" lub musisz posiadać odpowiednie uprawnienia, aby ta operacja się powiodła.
u mnie dało taki rezultat:
ls -l FreeCAD_weekly-builds-26306-Linux-Conda_glibc2.12-x86_64.AppImage
-rwxr-xr-x 1 kaktus kaktus 960640192 11-11 07:19 FreeCAD_weekly-builds-26306-Linux-Conda_glibc2.12-x86_64.AppImage
Karas1920 wrote: Fri Dec 03, 2021 8:10 pm Tel plik nie chciał się uruchomić. Zaznaczyłem, że ma być wykonywalny a mimo to sie nie uruchamiał. Włączało się to małe okienko niby się program ładował a potem się wyłączał.
podejrzewam że brakło Ci cierpliwości ... :roll:
Szczególnie pierwszy raz uruchomienie trwa dłużej, ten plik z programem jest trochę specyficzny, i przy pierwszym uruchomieniu powiedzmy. że co nieco "musi się wypakować".
Z twojego opisu "uruchomienie" zdaje się przebiegać prawidłowo, przynajmniej na wstępie.
Spróbuj odpalić toto z konsoli, wtedy dodatkowe komunikaty, które mogą się pojawić, mogą zdradzić tajemnicę co jest na rzeczy.
$ ./FreeCAD_weekly-builds-26479-Linux-Conda_glibc2.12-x86_64.AppImage
FreeCAD 0.20, Libs: 0.20R26479 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2021
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
Sheet Metal workbench loaded
po wyświetleniu ostatniego wiersza z komunikatem, musiałem jeszcze poczekać "kilka chwil" za nim wyświetlił się interfejs FC.
Owa ostatnia linia u Ciebie nie wystąpi.
trzymam kciuki
:mrgreen:
kwahoo
Post by kwahoo »
kaktus wrote: Sat Dec 04, 2021 5:45 am
Dodatkowo FC potrafi zapisywać logi https://wiki.freecadweb.org/Debugging/pl
Dla testu wrzuciłem Fedorę 35 na maszynę wirtualną i wygląda, że FC z Appimage działa, czyli problem musi być charakterystyczny dla konkretnej konfiguracji.
