Help wanted. Python script for second moment of area
Post here if you have a FreeCAD-related job to offer to the FreeCAD community. This can include programming or modeling.
ajarivas72
Postby ajarivas72 » Sun Jan 21, 2018 1:30 am
Hello
I am looking for a Python script that computes the second moment of area of a surface.
I need the second moment of area to compute the bending stress with the formula:
S = M * y / Iyy
where
M = bending moment
y : distance from the center of area
Iyy: second moment of area
The quantity I need is Iyy
Example:
For a rectangle of height "h" and base "b", the moment of area with respect to the center of mass is:
Iyy = b * h^3 / 12
The code must compute the Iyy correctly having a surface as an input to the script. The programmer must show several examples proving the correctness of her/his code and send the price to pay for her/his code.
We must agree to price, delivery time, and all the pertinent details.
Best regards.
Alejandro
UR_
Re: Help wanted. Python script for second moment of area
Postby UR_ » Sun Jan 21, 2018 12:13 pm
This is really not a big task.
Please see this quick'n'dirty example. It's for free :lol:
Macro:
import math
obj = App.getDocument("test_face").getObject("DWire")
shp = App.getDocument("test_face").getObject("DWire").Shape
MoI = shp.MatrixOfInertia
Ixx = MoI.A11
Iyy = MoI.A22
Izz = MoI.A33
Area = shp.Area
CoM = shp.CenterOfMass
Ix = shp.StaticMoments[0]
Iy = shp.StaticMoments[1]
Iz = shp.StaticMoments[2]
Ixxtrans = Ixx + Area * pow(CoM.x, 2.)
Iyytrans = Iyy + Area * pow(CoM.y, 2.)
Izztrans = Izz + Area * pow(CoM.z, 2.)
print "area ", Area
print "center ", CoM.x, " ", CoM.y, " ", CoM.z
print "staticmoments ", Ix, " ", Iy, " ", Iz
print "Inertia about [Gx,Gy,Gz] ", Ixx, " ", Iyy, " ", Izz
print "Inertia about [0,0,0] ", Ixxtrans, " ", Iyytrans, " ", Izztrans
Inertia.FCMacro
(718 Bytes) Downloaded 38 times
screenshot translated circle.png (60.2 KiB) Viewed 1747 times
File:
test face.FCStd
(5.12 KiB) Downloaded 23 times
Done with:
Version: 0.17.13005 (Git)
Hash: 29533320fc514029f3ce1af6bbf53cc03fb93049
Python version: 2.7.8
OCC version: 7.1.0
mario52
Postby mario52 » Mon Jan 22, 2018 5:17 pm
hi UR_
same result with Macro_FCInfo
interesting your macro
i replace your two first line with (for use directly with object selected)
#obj = App.getDocument("test_face").getObject("DWire")
#shp = App.getDocument("test_face").getObject("DWire").Shape
shp = FreeCADGui.Selection.getSelection()[0].Shape
I can add these code lines to my macro ?
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets. My macros on Gist.github
ajarivas72
Postby ajarivas72 » Sat Jan 27, 2018 5:28 pm
UR_ and mario52
I thank you very much.
ajarivas72
Postby ajarivas72 » Sun Jan 28, 2018 7:41 am
UR_
Hello.
How do you create DWire object from the Sketch in your file ?
Postby chrisb » Sun Jan 28, 2018 8:29 am
In Draft workbench is a tool DraftToSketch which converts in both directions depending on the selected input.
ajarivas72
Postby ajarivas72 » Sun Jan 28, 2018 9:00 am
Thanks a lot. It worked beautifully
Postby chrisb » Sun Jan 28, 2018 9:58 am
You're welcome. I use it usually in the other direction to convert from svg files to sketches.
lukassturm
Postby lukassturm » Tue Mar 13, 2018 1:37 pm
Hello forum, I am still really new to FC but I already spent lots of time using it.
Specifically I spent lots of hours on the problem of computing the 2nd moment of area (german: Flächenträgheitsmoment [unit: m^4] ).
I want to design an extruded aluminum profile for minimum weight and maximum bending stiffness.
The cross section will be far away from a combination of simple shapes, so I cannot calculate it by hand.
But I want to use the tool from _UR to compute Ixx.
My workflow becomes problematic towards the end:
Sketcher:
I design only one half of the cross section. I will try to attach this file.
Draft:
I use Draft2Sketch to get a DWire from the sketch.
Then I mirror the DWire at the x-axis (horizontally).
Then I use the upgrade tool to get one whole DWire (upper half and its mirrored lower half). But this does not work for me. I guess I do something wrong in the way I select parts during the upgrade procedure.
My goal: Have the whole profile cross section as DWire and use the script from UR_ to compute Ixx.
For the very simple profile (only its upper half is sketched) the result calculated by hand is Ixx=266cm^4.
Can somebody tell me what I am doing wrong?
Version: 0.17.13340 (Git)
Hash: 29864ff82173e501e220e754ccfe845b53990908
Python version: 2.7.14
OCC version: 7.1.0
Profil_200x10.FCStd
(7.57 KiB) Downloaded 21 times
ajarivas72
Postby ajarivas72 » Sun Sep 23, 2018 5:20 am
Hallo lukassturm
I did not see your message until today.
Tomorrow I will give you a look to your question.
Best regards
Auf Wiederhören.
Alejandro
