need CAD file developed for a small piece
Post here if you have a FreeCAD-related job to offer to the FreeCAD community. This can include programming or modeling.
MikeDee
Postby MikeDee » Sun Oct 14, 2018 5:56 pm
I can get you all the dimensions, just looking for a file I can use to print these with, I have a creality CR10. Need to print a few, and just not experienced enough with CAD yet
PM if you are interested, thanks
Re: need CAD file developed for a small piece
Postby chrisb » Sun Oct 14, 2018 11:16 pm
This does not seem to be very complicated and yet you have no responses.
I propose to move it to the help forum expecting that the community will build this model. In return you can make a donation to FreeCAD.
MikeDee
Postby MikeDee » Mon Oct 15, 2018 1:28 am
I'd be happy to do that, can you move it for me?
HarryGeier
Postby HarryGeier » Mon Oct 15, 2018 5:01 am
Mike, i do it for you.
Can you pass me the dimensions. I will make a tutorial while doing it.
Hatrry
Kaum macht man´s richtig , gehts´s
My Video Tutorials on Youtube: https://www.youtube.com/channel/UCoe3B ... p8Q/videos
My FreeCAD Stuff on Hidrive: https://my.hidrive.com/share/qr3l1yddy6#$/
czinehuba
Postby czinehuba » Mon Oct 15, 2018 5:05 am
Just send me the details I'll get it done for you.
MikeDee
Postby MikeDee » Mon Oct 15, 2018 5:18 am
Hatrry
Great, I'll get the calipers out in the morning and get dimensions over to you . Was hoping to learn how to do this along the way so having a tutorial I can follow would be amazing. Send me a PM with your thoughts about compensation, appreciate your help. Cheers
anna
Postby anna » Mon Oct 15, 2018 11:47 am
Hi Mike,
Sent you PM.
BR,
Anna
HarryGeier
Postby HarryGeier » Mon Oct 15, 2018 1:18 pm
no need for compensation.. too small the effort for such a bitty.,...
just give me the data and i will enjoy making it...
harry
MikeDee
Postby MikeDee » Mon Oct 15, 2018 2:08 pm
harry
Thanks Harry, I'll make a forum donation then, appreciate that.
Let me know if I missed anything. Tough piece to measure, all measurements in mm.
This is a "window glide", they fit in each corner of a horizontal sliding window in my home, 4 per window. The critical dimension is the overall width (20.75mm) which it the width of the track the sliding window sits in. This width keeps the window centered side to side so that the narrow rolling wheel on the frame rides correctly on the narrow track in the frame which allows the window to glide back and forth to open and close. There are indents on the sides of the sliding frame where the edges clip in, and a hole to accept the tall clip that is offset from center.
I can shoot a few photos of the frame with one of these glides installed if it would be helpful to visualize how the glide functions
ETA: the image has been cutoff on the R side, the cropped dimension is 1.69mm
another shot of the drawing with the part included: https://imgur.com/JEqCC1R
HarryGeier
Postby HarryGeier » Mon Oct 15, 2018 8:09 pm
2018-10-15 22_11_30-FreeCAD 0.18.png (238.01 KiB) Viewed 680 times
Hi Mike,
here is a first draft. Print it and see if it fit´s , then we can rework and add some filltes to make smoother etc..
You can tell me what to change, or try on your own. Just play with the constraint values.
If you want a new stl from a changed design, use the mesh design wb and make mesh from the pad , export and print it..
clip.FCStd
(49.59 KiB) Downloaded 20 times
clip.stl
(4.96 KiB) Downloaded 20 times
