Need to design mixing valve (pay to forum or members)
Post here if you have a FreeCAD-related job to offer to the FreeCAD community. This can include programming or modeling.
benc
Postby benc » Tue May 19, 2020 12:09 am
Looking to get the following into a STL or other suitable format. First goal is 3D print in inexpensive plastic for examination. After verification, last step would be milling in stainless steel. How much would this Cad work be reasonably worth?
Please forgive the caliber of the drawings.
Re: Need to design mixing valve (pay to forum or members)
Postby chrisb » Tue May 19, 2020 6:20 am
Hi benc,
you can attach the images directly to the post, that makes it easier to read without additional clicking. You may edit the post and replace the pdfs.
On the second image is a diagonal crosspattern to be seen. What should this be in detail? Is it a pattern to be applied?
How much is worth to you? I offer to do this as a community project and you donate to FreeCAD.
kisolre
Postby kisolre » Tue May 19, 2020 7:20 am
That is one ugly shaft :D
benc
Postby benc » Tue May 19, 2020 11:40 am
Hi benc,
Please excuse my ignorance, but I don't understand the mechanism to attach the images directly to the post. How would I do that? Edit: It appears that a PDF file does not want to appear inline. I'll rescan the pics in a gif or jpg format when I get back home.
Would you be comfortable with a $100 donation?
kisolre
Postby kisolre » Tue May 19, 2020 11:59 am
You can extract the images from the PDF directly. In Acrobat reader click on the image in the PDF, RMB/Copy image. Paste in your image editor, save to disk, attach to forum post.
kisolre
Postby kisolre » Tue May 19, 2020 12:00 pm
see above...
DeanY3
Postby DeanY3 » Tue May 19, 2020 6:29 pm
benc,
Does this look about right? I'd DM you but I've only been lurking the forum so that feature is disabled on my account for now.
Plastic Render.jpg (139.96 KiB) Viewed 281 times
Stainless Steel Render.jpg (142.34 KiB) Viewed 281 times
-Dean
______
\____@( ' ' )@____/
benc
Postby benc » Tue May 19, 2020 8:18 pm
benc,
Excellent work. Check your PM mailbox.
kisolre
Postby kisolre » Tue May 19, 2020 9:01 pm
Dimensions dont look right. Here is my take. Shaft is shorter for faster recalculation:
benc
Postby benc » Tue May 19, 2020 9:55 pm
Excellent work. It has a visual aspect I did not expect, but, the longer I look at it, the better it looks.
The "nub" sticking up at the left side 1 oclock position was unanticipated. If the groves were uniformly widened it would eliminate those 4 nub weak points and give better flow too.
