wildthinx wrote: ↑Sat Mar 13, 2021 7:53 pm Wow, that makes me happy to see. Thank you!
First of all: Mister Maker: "Schnitt.skp" was just an example to show that the object is hollow. It was just a cut through.
Adrianinsaval. So great, thank you again. Now I am a bit confused. Who of you did the job?
I modeled your part in FreeCAD and responded without seeing MisterMaker's response so I guess you could say both of us did the job in parallel
I would appreciate it if you can publish your donation to encourage people in the future to do this kind of jobs as a donation to FreeCAD, thanks in advance.You can send the file public. I will donate 20 USD today to the official donation.
I never used sketchup so I have no idea what you should do, therefore, as you predicted, my response is: use FreeCADBut I would also like to understand, what happend. Actually in Sketchup I gave it all a "solid". And I tried it several times. What can I change in the future? I mean, it is a bad question to ask for in a freeCAD forum. You will write: Use freeCAD. But I work with Sketchup for such a long time I would like to proceed.
Anyways, here is the freecad file in case you want to edit further and correct any dimension. The mesh and the corresponding shapebinders I used for reference can be safely removed if you want to have a cleaner tree, none of the constraints depend on them.
