Part-Designer
Part-Designer
Hello, I'm new with Freecad and my english is very bad. I'm searching for someone who can make 1 Part for me. 3D incl. 2D-PDF Drawing. In the attachement is a picture of the part. I can send the dimensions later.
- IMG_8526.jpg (76.56 KiB) Viewed 3675 times
Rechtschreibfehler sind pure Absicht und dienen nur der Belustigung des Lesers.
Re: Part-Designer
Hi and welcome to the forum!
Would you be willing to donate to the project if we create a community solution. And if so, how much would it be worth?
Re: Part-Designer
Hello, i think it is only 1 small part. And i can pay approximatly 30€ for that. I need the 3D Step file and 2D pdf-Files for a CNC-Shop that they can produce it for me.
Re: Part-Designer
Now a few dimensions:
The inner hole -> 20 mm
The outer thread -> 1,37"x24 BSA 60°
The Keyway -> 6 mm wide
The fixing thread -> M5
distance between the parallel surfaces -> 34 mm
I think it is less than 1 hour work.
Re: Part-Designer
I can give it a try, if someone can give me a pointer what kind of thread this is. Is it diameter and tracks per inch? Or even better, to make it a real community thing: I do the rest, someone else makes the thread.
Re: Part-Designer
Thx. It is a bicycle thread for a freewheel. 1.37 inch diameter and 24 turns per inch.
Re: Part-Designer
I can make this work with 25 euro.
Re: Part-Designer
Thx, for your offer. I will wait for the try of chrisb and if it does not work, than you can do it.
Re: Part-Designer
ok
thanks
thanks
Re: Part-Designer
I will do it in a couple of hours, have to go now.
