Here, I changed section icon a bit. Also, I see contours does not look clear enough with dark background. So, I made the white lines a bit thicker.HakanSeven12 wrote: ↑Sat May 30, 2020 5:53 am Looks good my mesh is not like a box. It represent the earth surface. Here an example
[Help]Icons for Trails Workbench
Re: [Help]Icons for Trails Workbench
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
- HakanSeven12
That looks better Can you do something for "export points to file" icon?(the second icon at the picture)
- new icons.png (8.95 KiB) Viewed 3286 times
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
Here you are... Are these point symbols clear enough? Should I change them from blue to a whiter color?HakanSeven12 wrote: ↑Sat May 30, 2020 2:04 pm That looks better Can you do something for "export points to file" icon?(the second icon at the picture)
::bitacovir::
- HakanSeven12
Maybe you can make it bigger and remove paper from background and you can use a whiter color
The paper is a global convention for documents and files and it is behind the other icons, so It does not interfere. But I made bigger the point symbol and in yellow color.HakanSeven12 wrote: ↑Sat May 30, 2020 2:47 pm Maybe you can make it bigger and remove paper from background and you can use a whiter color
::bitacovir::
- HakanSeven12
Seems fine
- HakanSeven12
I tested them looks nice thanks for help
- new icon.png (14.91 KiB) Viewed 3160 times
- HakanSeven12
Hi. I need an icon. If you have time, can you make an excavator icon?
Sure. With pleasure. Any color in particular?HakanSeven12 wrote: ↑Mon Feb 22, 2021 3:10 pm
::bitacovir::
A couple of ideas. The color is optional.
::bitacovir::
